Author Subject: Drive shaft removal?
fugs
I want to change the drive seal in my drive shafts. How do you remove the shaft from the box? Does it just pull out or is there something holding it in?
Posted 10th Apr 2010 at 00:12
stuart638
Passenger side pull straight out. Drivers side, you need to undo the little hockey stick bolts in the lower engine mount. It 'should' then just pull out. If it's not been removed for a while, you may need to use a persuasion tool to free the bearing from the housing.
Nothing holding the shafts in the diff though.
Hope this helps....Stu
Posted 10th Apr 2010 at 01:18
fugs
Thanks. Is the drive seal just in behind that than?
Posted 10th Apr 2010 at 01:41
stuart638
The seals are in either side of the diff housing. The bearing half way along the drivers side shaft just sits in the metal housing of the lower mount.
Posted 10th Apr 2010 at 02:41
matt evans
Im having driveshaft seal issues on my passanger side shaft, am i right in assuming theres nowt holding the shaft in the box (circlip wise?)?
I cant see any groove in the shaft where one would locate and the shaft just slid out of the box with no resistance what so ever.
Normally on previous cars, ive had to pop the shafts out with a pry bar, on the 306 it almost fell out LOL
honestly3k wrote:
owain wrote:
Posted 28th Apr 2010 at 01:53
fugs
Thats normal Matt. Mine fell out to. Simple job to change the seals. I don't know why I made a big fuss about it!
Posted 28th Apr 2010 at 15:59
i have to refit my shafts and new seals sometime this week. i am looking forward to it
Posted 28th Apr 2010 at 21:08
