Author Subject: 16mm or 18mm
frickinraz
Hi, I need a new ball joint, will it be 16mm or 18mm, its a phase 1?
Команда Cossak
Team Yellow Fogs
Posted 14th Apr 2010 at 00:15
davidmartin
16 mm mate. part no 364037,as long as it hasn't been messed with.
pet hate, the cat
Posted 14th Apr 2010 at 00:18
frickinraz
Thanks mate!
Команда Cossak
Team Yellow Fogs
Posted 14th Apr 2010 at 00:20
farmer
should be 16mm you mean....
Mine is 16mm on one hub; 18mm on the other hub Roll eyes....
Long live the Sigma 6 Big grin
Team Phase 1 supercharged
XBL ID: farmer uk1
Posted 14th Apr 2010 at 01:57
davidmartin
don't think you're alone,The meridian I had was the same.
pet hate, the cat
Posted 14th Apr 2010 at 04:02
smevs
Hey guys, im new to this forum but i have noticed alot of talk about 16mm and 18mm ball joints. But another thing i have noticed is that on the peugeot parts site the hubs themselves are exactly the same part number regardless of the ball joints used (the only exception being the 1.4), so surely either ball joint can be used; its just a matter of spreading the gap into which the ball joint pin slides. Afterall, it would only be 1mm of extra spread for each side of the pinch bolt?
I drive a Peugeot, yet i always recommend a Honda?
Posted 19th Apr 2010 at 15:38
cwspellowe
I wouldn't risk that tbh, i did something similar with mine and it's ovalled the hole on the hub, can't get it round again so there's a lot of play in it leading to some dodgy steering.
Should definitely look to get the right sized ball joint rather than trying to pikey things.
Bye bye Sundance Kid Sad
Posted 19th Apr 2010 at 17:26
smevs
Well, now i know! I wasnt belittling the(extensive) knowledge of this forum, just clarifying. Just seemed odd that all hubs were the same part! Maybe ill try it on some junk hubs and see how get on before attacking my own!
Posted 19th Apr 2010 at 22:03
Rich E Forum Admin
The hubs are different and you need to use the correct size ball joint.
Hub part numbers:
16mm
Left - 3646 53
Right - 3647 53
18mm
Left - 3646 54
Right - 3647 54
Posted 20th Apr 2010 at 02:45
smevs
It appears i have made an error, upon checking servicebox there are instances in which a 16mm balljoint appears with the later hubs. However, in a small note "See A", it does mention that it is in fact the 18mm joint that is required. Cheers for clearing that up guys.
Posted 20th Apr 2010 at 05:26
