Author Subject: Running on 3 cylinders - Arched coil!
nzgti
Hey Guys, I need some help with my 2000 GTI-6
The engine light is on and running very rough
The AA came and checked it out and it is only running on 3 cylinders and one of the Coils has no spark.
I replaced the coil and it melted within 1 minute!!
Any suggestions to what is wrong?
cheers
Posted 14th Apr 2010 at 13:10
mechanical_repairs
Very odd, when you say it melted do you mean the electrical connection end or the part that goes over the plug itself?
Carl
Posted 14th Apr 2010 at 13:24
nzgti
The coil sparked and there was a burning smell. There is a crack in the side of the coil. I will try and put a pic up. cheers
Posted 14th Apr 2010 at 13:41
nzgti
pic of coil
nzgti has attached the following image:
Posted 14th Apr 2010 at 13:46
nzgti
$270 NZ dollars gone in 1 min
Posted 14th Apr 2010 at 13:48
stuart638
Sounds you like you might have a electrical short to that coil pack? Might be worth unplugging them all and checking the voltage at each plug.
I have had a similar problem after I'd had the plastic cover off. I'd trapped a wire and shorted it!!
Posted 14th Apr 2010 at 15:05
mechanical_repairs
Jesus mate there not cheap, i sell them second hand here for £10, unsure on the exchange rate but its got to be loads cheaper.
As above check the wiring as it comes around the head on the metal bracket, seen a few break the wires around there.
Carl
Posted 16th Apr 2010 at 12:54
nzgti
I might have to take you up on those second hand ones Carl.
The Peugeot dealer rang today and said that I needed 4 new coils and that there was only 1 left in New Zealand.
Apparently $470 NZ each from France! what a rip off.
They are sending the ECU away to be checked too!
Im trying to source some coils locally at the moment.
Nic
Posted 16th Apr 2010 at 13:05
nzgti
Thats 217.137 GBP per coil.
Posted 16th Apr 2010 at 13:07
mechanical_repairs
Jesus, just let me know and i can sort you some out, got to send some parts to Australia tomorrow for another customer.
Cheers, Carl
Posted 16th Apr 2010 at 13:12
nzgti
The car is all fixed!
No fault with the ECU, 4 brand new coils and its all good.
Thanks mechanical_repairs for your offer. I ended up getting some brand new coils from peugeotpartsdirect.co.uk. Very good service and price!
Posted 6th May 2010 at 04:04
