Author Subject: FUEL PUMP KEEPS PRIMING WHEN KEYS OUT
Paddy Power Turbo Banned!
my fuel pump keeps priming its self even with the keys out and car locked !! the radio also stays on when the keys are out and the cars locked , would the fuel pump be wired direct to the battery, aswell as the radio ,Huh? id really like some help and idea's please whats gone wrong Sad
TEAM(FIGHTIN IRISH)COMIN TO A PUB NEAR YOU !!!!
ps3 online name : butcherboy200
dyno print out : 185.4 at the flywheel
modern warfare 2 Wink
Posted 29th Apr 2010 at 06:44
Rich E Forum Admin
The ECU primes the fuel pump when the immobiliser kicks in. I've no idea why it's programmed to do this but it's normal.
As for the stereo there are two positions you can set the fuse to. One gives a switched live from the ignition and the other gives a permanent live from the battery.
Posted 29th Apr 2010 at 07:15
shud it not stop after a few times say 3 or 4 and then stop ? as for the radio it came back to me that way after a guy done the timing belt he says he didnt do anything LOL he must of cause it was all fine before he touched it
Posted 29th Apr 2010 at 07:21
Rich E Forum Admin
If the fuel pump won't shut off then the most likely culprit is the double relay on the back on the battery box.
Posted 29th Apr 2010 at 07:23
are they expensive to replace ?
Posted 29th Apr 2010 at 07:29
jimmyhackers
i have this problem with my xsi. the fuel pump primes itself when the keys are out.although it primes itself every 20-30 mins or so indefinately. i have swapped the double relay over from two other 306's and the problem remains.
could it be im loosing pressure slowly in the fuel system? like a leaky injector or valve etc?
Posted 8th Apr 2012 at 13:37
That's quite normal, they all do it apparently, dunno why LOL
your thing is quite different to the OP's issue.
EPIC bump btw LOL
Posted 8th Apr 2012 at 13:40
atterz
Whats this about fuse position for the radio?
owain wrote:
Posted 8th Apr 2012 at 15:57
darzmat
i would also like to know his. would love to have a perminant feed to it.
Posted 8th Apr 2012 at 16:59
eddiebeano
+1 I can't keep my head unit settings!
team: Stealth Ninja
Posted 8th Apr 2012 at 19:07
rich306.
I have the same issue with the fuel pump, as you say just ever 15 - 25 mins. I've never been concerned though, I just assumed it was ment to on the relay...
Ex Bianca 6 Owner R.I.P
Mazda RX7 FD3s - Daily...
Posted 10th Apr 2012 at 10:47
russbez
in my Rallye iv same issue with the fuel pump
pretty sure its normal LOL
eddiebeano wrote:
darzmat wrote:
i would also like to know his. would love to have a permanent feed to it.
i had same issue with my 306 estate
you can have your stereo and/or the 12v wired up with a live all the time
good to have the choice, cannot do it in a Rallye right enough! "Cheaper" fuse board i guess.
if you look in your manual it explains it there, basicly you move the fuse for your stereo"down a notch" (or up! cannot remember which fuse number does stereo)
most fuses only have 2 notches, your stereo (and 12v) has 3.
This lets you choose from permanent live or live when ignitions on.
My Rallye project thread
Posted 10th Apr 2012 at 10:56
eddiebeano
Cheers russ! Will check this out today.
team: Stealth Ninja
Posted 10th Apr 2012 at 11:02
darzmat
Done this just now its fuse number one and moves down one notch
Posted 10th Apr 2012 at 23:34
jimmyhackers
everyone keeps saying this random fuel pump priming is normal. I dont think i rember it happening on my phase 1 1.4 or either of my phase one gtis? Am i going mad?
Posted 13th Apr 2012 at 10:12
jimmyhackers
Posted 13th Apr 2012 at 10:13
darzmat
i think you went mad a long time ago Thumbs up
mine has done it since i got it. asked about it on here over a year ago.
Posted 13th Apr 2012 at 12:06
