displaying posts 26 to 29 of 29
Pages (2): 1 [2]
Author Subject: Brake hose replacement
GTI-6
http://sdrv.ms/ZuSVo7
http://sdrv.ms/ZuT6jd
http://sdrv.ms/ZuT8HN
Love thy 6
Posted 10th Jan 2013 at 09:15
GTI-6
I couldn't put them up as I dont know how to, but those are links. I uploaded them to skydrive.
You can see the slightly blurred one is the spline part that sits in the bracket, I chopped it with a grinder as I needed to get it off and I was losing my temper, so I stopped!
Love thy 6
Posted 10th Jan 2013 at 09:18
the spline part is part of the front flexi hose from the caliper so you'd need a new front flexi, and then have to make a new section up for the bit it connects to (square U shaped which you've cut). you could join them together using couplers and a flaring tool like a Sealy one and a short section of like copper/kunifer pipe, you have a couple of options really. i never like joining brake pipes together and would probably prefer to replace the full pipe using new pipe
Posted 10th Jan 2013 at 09:28
GTI-6
ok mate thanks. Ive got a new flexi sat here.
I think there's enough pipe to flare it and fit to the flexi on the bracket.
I'll give that a crack with either a flaring tool if I can get one cheap or Ill roll it to a brake shop nearby.
I argee, joining a brake line is just a bad idea.
Don't understand how anyone thought it would be good to use a soft metal for a retained fitting and a hard metal for a replacable part like a flexi hose connector.
Thanks heaps dude
Love thy 6
Posted 10th Jan 2013 at 09:38
Pages (2): 1 [2]
