Author Subject: Intermittent misfire
kennny
Hi ive just recently bought my 6 but nticed a small misfire which occurs intermittently. It usually occurs when i put my foot down and the car dies for a second then comes back and does it several times but then will run fine after for a while. Could this be coil packs? Also sometimes when i start the engine (hot or cold) it sometimes cuts out but starts again. It sometimes cuts out then starts then cuts out again and wil stay running with a bit of throttle.
Any ideas?
Kenny
Posted 16th May 2010 at 22:23
kennny
Does nobody have any ideas?
Posted 20th May 2010 at 13:40
ann306
I got the same problem and need some advice 2
Posted 21st May 2010 at 04:34
dan@msx
idle control valve, throttle position sensor or MAP sensor..... or a bad earth? mine started doing this..... Sad
Posted 31st May 2010 at 07:17
