Author Subject: partner and berlingo wishbones
jonnie205
Had a look at a partner and berlingo today. It looks like the front subframe are the same as 306. the partner had cast wishbones while the berlingo has pressed steel ones like 306. Does anybody know if the berlingo or partner wishbones are longer, ie can be used on a 306 to give negative camber etc? also mthe cast ones could be a good upgrade for track cars as i would think they flex less
Posted 26th May 2010 at 00:14
Rich E Forum Admin
I've noticed before on Servicebox that the Xsara VTS shares some suspension parts with the Partner but nothing cross references to the 306.
It would be interesting to see some side by side with 306 items Yes
Posted 26th May 2010 at 00:47
dented_vts
I think they are the same- i believe the ones ECP sell for the Xsara come up as Partner on the sheet. Do the hubs look the same? I'll check my records when home.
For neg camber- do AST not do adjustable top mounts?
Posted 26th May 2010 at 19:51
AST do make 2 way independently adjustable top mounts yes Smile
as for the rest of it, the bulkhead forwards under the exterior panels are near identical to a 306/xsara.
Posted 26th May 2010 at 23:40
Yes but they won't give you all that much. If they are longer wishbones will the standard shafts have enough spring in them to cope? Don't see why you couldn't make a balljoint longer somehow (cue phil with some rosejoints...)
Posted 27th May 2010 at 17:28
clen666
Just get him to knock up some of his tubular rosejointed wishbones, not sure what adjustment they have already but I'm sure he could extend them a bit.
Though not as cheap as wishbones from a scrappy... Whistle
Team 'unintentional rat look'
Posted 27th May 2010 at 21:16
they wont be longer wishbones, they use the same length driveshafts.
Posted 28th May 2010 at 00:12
They've got enough adjustment that I run out of driveshaft travel before I run out of wishbone adjustment Wink
Posted 28th May 2010 at 00:22
chop chop, weldy weldy Razz
Posted 28th May 2010 at 00:51
Thinking about it...
Posted 28th May 2010 at 04:01
get some 406 BE shafts, then you just need to shorten them instead of add metal LOL
Posted 28th May 2010 at 04:55
And fit the MA joints...
And they're extra weight!
Posted 28th May 2010 at 05:00
hmm, ahhh you have the smaller non ABS MA joints, not the larger ABS type that's the same as a BE joint, glad you only have 99 wabbits then LOL
thread hijack? Laugh my ass off
Posted 28th May 2010 at 05:19
Just a bit!
Yeah, I'm on the special lightweight racing joints Whistle
Posted 28th May 2010 at 05:32
