Author Subject: Timing belt problem (XU7JP)
stainbox12
Long story short. I had to pull down the engine, to resurface the block since i overheated, i replaced the valve guides on the head and the valve seals. Everything is back together, but i cant put the timing belt correctly. Im following the manual, that says you need to lock the camshaft and crankshaft with dowel pins. Everything seems to be fine, but whenever im done putting the belt back together, the crank only rotates half a turn, i cant seem to give it a full turn, If i change the position of the camshaft without the belt on, then i can turn over the engine fine with no problems. It seems that some valves are hitting the pistons, and thats why i cant turn the engine over. Whats going on here, this cant be difficult, Its rather easy to do. Thanks for the help.
Posted 28th May 2010 at 14:28
barry.rs
Has the bottom pulley slipped so that the locking position is in the wrong place?
NB. Im no expert though Laugh
Posted 28th May 2010 at 14:43
stainbox12
Not at all, They were both in position with the dowler pins in, until removed to turn the engine over by hand.
Posted 28th May 2010 at 14:45
did you fit the timing pins before removing the belt initially?
if not its quite likely that the outer section of the harmonic balancer incorporated into the crankshaft pulley has slipped.
also don't forget that this engine like the XU10J4R and RS have adjustable camshaft pulleys and require the bolt/s to be slackened when fitting an tensioning new belt.
lastly, if you have turned this engine over and it has locked up, you will have bent at the very least two valves which will require replacing and the seats cutting at the very least.
Posted 28th May 2010 at 15:04
stainbox12
Yes, i think i found the problem, and its exactly what you guys stated earlier. I found it in the link here: http://www.306gti6.com/forum/showthread.php?id=37838&page=1
I checked the pulley and in fact it has slipped/rotated, and thats why i was not able to set up the timing correctly. BTW, i didnt fire up the engine, i was turning it by hand and it was locking up, i dont think that it will bend any valves doing it it that way, i was just testing.
Thanks very much for the help. Its really appreciated. Big grin
Posted 28th May 2010 at 15:34
you WILL bend valves if they hit the pistons, they only have 6mm stems and fairly large heads, so are quite fragile!
Posted 28th May 2010 at 15:47
stainbox12
Hmmm.. just by turning the engine by hand? i was just rotating the assambly to make sure everything was right. Of course it wasnt. Even the manual says to give the engine 2 full turns and so on, to make sure it rotates freely, what happens if it doesnt? then you automatically bend the valves? I dont think so, they are metal not plastic. Once again, i have not turned on the car yet, im still in the process of putting everything back together. I will use another known good pulley to set up the timing.
Posted 28th May 2010 at 23:30
