Author Subject: split braided hose
rallye1999
, just went to put my car onto a set of ramps and while using the brakes the pedal went to the floor followed by lots of blue smoke as the brake fluid hit the manifold, is this common for a brake hose to leak? its on its length nowhere near a join
Posted 29th May 2010 at 17:41
chris with a pug
How old are they? where did you get them from?
I havent heard of any splitting, I was under the assumption you fitted and forgot
Posted 29th May 2010 at 17:57
jeffers Forum Admin
I did exactly this with a goodridge one a couple of weeks age.... guess it can happen.....Unsure
Team Running Engine again!
Team Negative Camber!
Posted 29th May 2010 at 18:01
mr swampy s16
**BAD SELLER**
It can happen though is less common with braided lines.
Normaly a sign it has being damagd or rubbed on a wheel
I can supply a single hose if required
Posted 29th May 2010 at 19:00
rallye1999
thanks, I'll let you know dimensions as it's a 1 piece hose from master cylinder to caliper, looks like a wire has caught on the braid and fried it lol
Posted 29th May 2010 at 22:48
i've wrapped all my stainless brake pipework throughout in 4mm convoluted sleeving to protect it where it is out of the car [most of it's inside though out of harms way]
Posted 29th May 2010 at 23:10
rallye1999
I think I will fo the same when I've sorted it lol
Posted 29th May 2010 at 23:23
chris167
i would be just as concerned about why a wire has fried the line aswell? please tell me im wrong in thinking its a bare wire
There are currently 1 people online
Most ever was 173 on Sunday 9th Nov 2008 at 8:04pm
Registered Users: chris167
Posted 31st May 2010 at 01:02
mr swampy s16
**BAD SELLER**
i can supply them with a clear plastic protective cover if required
Posted 31st May 2010 at 01:07
rallye1999
it was a wire i thought wasn't live but it turned out to be,
Posted 31st May 2010 at 03:14
