displaying posts 351 to 375 of 571
Pages (23): first .. 14 [15] 16 .. last
Author Subject: Astor GTi-6 OEM+
matt evans
Post #351
bigbadbowen wrote:
You are having the powder coated right ?
Oh yes, its going in tomorrow to be done, as its quite nasty!Thumbs up
honestly3k wrote:
owain wrote:
Posted 15th Apr 2012 at 23:09
danposs86
Post #352
matt evans wrote:
PMSL - i'm painting a set of cam covers red crackle at the moment for a fellow forum member as we speak (in primer at the moment) so maybe theres more of us with taste than you think?
I'm painting mine up crackle red (VHT Wrinkle), what primer are you using and do you need primer, a few guides I have seen say you dont need it.
danposs86's GTi-6
Posted 19th Apr 2012 at 18:49
matt evans
Post #353
I always use Acid Etch primer, a light dust coat, then 2 normal coats, then crack on with the Wrinkle paint.
Posted 19th Apr 2012 at 21:10
t3ora
Post #354
matt use's etch primer first then paints it with VHT paint
Road/track car coming together slowly
Posted 19th Apr 2012 at 21:12
matt evans
Post #355
I'd removed the exhaust manifold ages ago, nothing out of the ordinary in its condition, normal condition in fact for a well hidden bit of steel piping thats 12 yrs old..
A local firm to me, GB blasting do all sorts of media blasting from coarse shot, down to aluminium oxide and glass bead blasting which gives a good non damaging finish.
Ive had the manifold blasted and its come out like this.
A close up of the finish.
Genuine pug manifold to cat fitting kit..
And a couple of the manifold fitted to the engine, with new studs and lock nuts.
The heat shield (steel one) which bolts to the rear cam cover has also been blasted, and thats been painted this evening in VHT silver, i'll get that refitted in the morning.
Tomorrow will see the subframe /rack/ bottom arms being built up on the bench. More pics to follow.
Posted 20th Apr 2012 at 21:14
Post #356
NiceCool
Would it be worth painting with VHT now its totally rust free?Dunno
Just thinking it might stay rust free longer?Dunno
Posted 20th Apr 2012 at 21:53
matt evans
Post #357
I'm gonna leave it as is Kev, not a fan of painted manifolds. In time it will discolour with use like a new one would, if i paint it and it starts flaking off it'll drive me mad looking at it.
Posted 20th Apr 2012 at 22:13
jeffers Forum Admin
Post #358
This thread is just porn! Hats off to you sir, anyone looking to turn their motor into a very clean example/ show car needs to read this! I wish I had the time and space plus a car in good enough nick to do it to! Thumbs up
Team Running Engine again!
Team Negative Camber!
Posted 20th Apr 2012 at 22:16
marco gti6
Post #359
What a lovely looking engine Mat Love
Things like this make me feel so ashamed of my engine bay Sad Once me and the missus buy a second car as winter/daily driver and i have the space/time/money i'll use your project as a guide Thumbs up
Looking forward to the next pictures.
Posted 20th Apr 2012 at 22:38
clen666
Post #360
Do you have the part numbers for the exhaust studs and nuts please?
Team 'unintentional rat look'
Posted 21st Apr 2012 at 07:22
stu
Post #361
Just had a quick look on Servicebox, I think they are -
0355 68
STUD
M8X125 IM15 L32 E6
0341 22
NUT WITH BASE
8X125-11-17,5
6935 86
SELF LOCKG NUT
DIAM 6X100-5,5-10
I'm sure someone will correct me if I've got the wrong ones.
Posted 21st Apr 2012 at 07:31
clen666
Post #362
Thanks Stu.
Are the copper ones 'nut with base' or 'self locking nut'? Where are the other ones located?
Posted 21st Apr 2012 at 08:12
matt evans
Post #363
Clen - self locking nut i'm sure. I'll see if i can dig the receipt out to check.
Posted 21st Apr 2012 at 08:23
jord294
Post #364
You can get clear vht paint.
I used it on my shotblasted ex manifold when I restored my 309gti.
Couldn't fault it Big grin
Posted 21st Apr 2012 at 09:06
matt evans
Post #365
Good shout Andy. Gonna order some later me thinks.Thumbs up
Posted 21st Apr 2012 at 09:18
clen666
Post #366
Cheers mate
Posted 21st Apr 2012 at 14:05
matt evans
Post #367
Finished painting the steel heat shield that lives on top of the manifold -
Then made a start on the front subframe, which ive had covered up for the last couple of weeks.
Fitted the gear likage "swivel"?
Then tried to remember which way round the ARB went LOL
Fitted the overhauled bottom arms, having changed the direction of the ball joint bolts, fitted the Xsara VTS steering rack, using the OE Xsara ram "sleeve" that came with it as its almost perfect.
At the moment all bolts are nipped up, except the rack to subframe ones, the others will be tightened up on the car when the weights back on the wheels.
Posted 21st Apr 2012 at 14:43
tvrfan007
Post #368
I lol at the close up of glass bead blasting. Laugh
It's something i'm so used to as all the last stage blade slots on the turbine are glass bead blast cleaned, everything else is ash blasted so i get all my blasting done FOC at work - never known anyone pay attention to the finish like that before. Laugh
I'm Si btw Tee hee
Night Blue VW Golf GTD
Posted 21st Apr 2012 at 16:59
clen666
Post #369
Is there only one common grade of glass bead blasting?
As I think that may be a good way to go with my brembos
Posted 21st Apr 2012 at 17:18
matt evans
Post #370
Ha ha - Im an office boy Si, therefore easily pleased PMSL!
Posted 21st Apr 2012 at 19:20
matt evans
Post #371
As far as I know, yes.Dunno
Posted 21st Apr 2012 at 19:21
matt evans
Post #372
Got the inlet on this afternoon, however im left with 3 x plugs which im unsure of.
First one is on the same little bit of loom that connects the Map sensor. Am i right in thinking this is the "spare" plug that does nothing on the 306?
Next two are underneath the throttle body, the blue one is the PAS sensor if i remember? However where does the black one go??Dunno Dunno
How it stands this afternoon.
Posted 22nd Apr 2012 at 16:57
mechanical_repairs
Post #373
The black one is a spare, the blue is power steering and the last is a spare too.
Looks really smart, like mine did two years ago.
Well worth it mate, makes me smile every time I open the bonnet.
Carl
Posted 22nd Apr 2012 at 18:45
matt evans
Post #374
Carl
Thumbs up Thumbs up Cheers Carl, ive been out there fooking ages looking to see what was unplugged, even got the inlet off again and couldnt see anything!LOL
Thanks for the compliments, had one of them weekends where i have hated the car TBH, at least the ends in site now.
Driveshafts have been tarted up, hubs will be painted on the car once the engines back in.
Posted 22nd Apr 2012 at 19:58
306 Rxs
Post #375
The rocker covers were painted by you or was it a paint job from a local shop?
What is a hybrid?
Honda engine...Ford brakes...Peugeot chassis...Vauxhall steering...
Posted 22nd Apr 2012 at 21:42
