displaying posts 26 to 50 of 79
Pages (4): 1 [2] 3 .. last
Author Subject: 240bhp
lotek
Thumbs up
Posted 31st May 2010 at 05:00
I'm hoping for 240+ from mine, anything less and I'll be seriously diasppointed.
Posted 31st May 2010 at 05:01
adamski_306
chrisgti wrote:
Easy to do mate I am at 270 now
Blink
So what are you running to get 270!!!???
Posted 31st May 2010 at 05:07
oldbrownshoe
part that go spin at 9500 RPM
French military victories?
Did you mean French military defeats?
Posted 31st May 2010 at 05:15
adamski_306 wrote:
Blink
A lot of Longmans parts I imagine Wink
Posted 31st May 2010 at 06:35
309btcc
**DODGY SELLER**
Posted 1st Jun 2010 at 23:20
309btcc wrote:
f*ck longmans jim that btcc engine liam sold that he baught for 6k only made 240bhp the guy who he sold it too dynod it. when pug-performance told us it was 270bhp 30bhp short as usual
Did it have the full maniflow system? And did he dyno it to a full 9K?
Posted 31st May 2010 at 19:02
309btcc
**DODGY SELLER**
chrisgti
No longmons bits all custom done by pug1off
270 bhp N/A Made by pug1off
¼ mile 13.6
Posted 31st May 2010 at 22:06
pugheaven
Post #35
Chris was it not limited to 8250rpm and was never mapped, iirc your bro used nicks map?
Posted 31st May 2010 at 22:12
chrisgti
Post #36
No it has always been mapped mate and it's reving to 9.5k it just has got a shift light on it as it goes off the clock.
¼ mile 13.6
Posted 31st May 2010 at 22:16
gtomi-6
Post #37
I was told liams car hadn't been mapped either. Touring car spec by longmans is about 264- 270 I wouldn't say pug 1 off is any better they are bassically doing the same thing .
ph3 gti-6 china blue- mint condition
ph2 gti-6 nile blue K.I.A dec 2010
Posted 31st May 2010 at 22:25
Post #38
240 ish and near 200 lbft is quite "easy" from the S16 for relatively little if you don't mind extra CC's, I'd imagine the gti6 could produce similar results from the same recipe.
it'll cost you a set of pistons and rods, overbored block, 92mm stroke 2.1 Diesel crank, inlet cam upgrade, Colin Satchel's throttle bodies, maniflow exhaust manifold.
If you want a similar power from 2.0 you'll need to chase more revs which means more cam, inevitably more peaky.
"touring car" spec from Longmans depends entirely on which year and what intake they were running, there were a few variants from 240 to 270 afaik.
As Miles said, the 306 had to run to quite specific regulations, and hence the cam profiles used were somewhat of a compromise, without limitations you can get a far better cam off the shelf or custom ground.
Posted 1st Jun 2010 at 00:35
miles
Post #39
The TC engine figures where always overrated, But if you want a good engine the only place is Sodemo, No one else comes close
www.pugracing.com
Posted 1st Jun 2010 at 00:37
alastairh
Post #40
309btcc wrote:
full maniflow and manifold yes full 9k was shit m8 longman aint as good as he is made out too be i fink the best peugeot tuner is pug1off they have some serious pugs atm
I heard from a reliable source that they had been dealing with some 290ish BHP NA RS engines.
Certinly not to be sniffed at if it is what it claims to be.
205 GTI6
Primera GT
Xsara VTS
306 GTI6
Posted 1st Jun 2010 at 02:44
pete_rallye
Post #41
I have a 'btcc' spec engine in my touring car now, 309btcc's bros old one. I never thought it would make anything more than 250bhp as the touring car engines never made that much in btcc trim. The cams are only about 0.4mm higher lift than standard GTi-6 cams, just longer duration, the rest of the engine is a good spec though so some bigger cams and springs if required soon make them nearer 270bhp. My original touring car engine made 240bhp with the 'standard' inlet manifold on, this one with ITB's on peaked at 252bhp@9k rpm, but settled at 245bhp with a better power curve. Won't be revving it to 9krpm though, probably 8krpm will do, and lose about 10bhp.
Revving to 9.5k may be good for bragging rights but 270bhp at 8.5k would be much nicer to drive!
Lap of the 'ring
Posted 1st Jun 2010 at 04:16
Post #42
James Lumleys EX-BTCC engine on Jenvey bodies made 274 bhp, but I dont know any more of the spec.
Posted 1st Jun 2010 at 04:25
pete_rallye
Post #43
Whos dyno was that on? Theres only a few 'original' spec engines left, most have higher lift cams in now. I'd be interested to see what Carls 306 makes as I believe thats still original.
Lap of the 'ring
Posted 1st Jun 2010 at 04:29
Post #44
What's the most anyone has got from one of these engines on a set of 45mm bodies? I'm a little concerned that I won't have enough flow for big top end figures as most of the high power NA guys seem to be on 48s.
Posted 1st Jun 2010 at 04:51
Post #45
I know DrSarty on drivers forum made 196 lbft and 240 odd bhp through 46mm bodies.
Posted 1st Jun 2010 at 05:23
miles
Post #46
You get get over 300bhp I say without too much troube but you need a few ££££, Might need some larger bodies thou
www.pugracing.com
Posted 1st Jun 2010 at 07:25
Post #47
Looks like theres a good chance I won't be held back too badly by 45s then? Coupled to an 8 injector setup I think I should hopefully get the power I'm looking for.
Posted 1st Jun 2010 at 14:00
Post #48
as long as you have a decent matched length inlet tract you'd be fine I'd imagine.
Posted 1st Jun 2010 at 15:18
Post #49
I think Jenvey do bolt in spacers, if they do I might experiment a little on the rollers when it's finished.
Posted 1st Jun 2010 at 15:27
Post #50
I was alluding to a proper inlet rather than an off the shelf point the trumpets at the bonnet item LOL
but that is more cash !
Posted 1st Jun 2010 at 15:31
