Author Subject: Spoox top mounts
chrisd306
Right im looking at getting a set of spoox mounts, there adjustable camber i think, are they any good, anyone got them?
In my garage just now
& Audi Q5 S Line
AX stock rod & Saxo Stock rod
Posted 1st Jun 2010 at 00:15
chrisd306
http://www.spoox.co.uk/catalog/product_info.php?products_id=172&osCsid=5cce00dd8c116832f0ffe355d7a3dc5e
basically same as these
& Audi Q5 S Line
Posted 1st Jun 2010 at 00:22
tez_306
i 2nd this question - any experiences lads?
Posted 19th Jun 2010 at 18:49
chrisd306
i dont think spoox do these for the 306, would 205/309 ones fit a gti6
& Audi Q5 S Line
Posted 19th Jun 2010 at 20:14
khj100
Yes they do
They're good quality, offer a good amount of adjustment and fitting is relatively easy.
You'll need to drill a hole in the strut top housing for the 3rd mounting point, and depending what springs/dampers you've got (i've never installed with standard ones) you'll possibly also need a flat upper spring seat
PS, Chris, can you reduce the size of your sig just a wee bit!?
Posted 19th Jun 2010 at 20:20
puglover Banned!
they are good enough im unsure about the bearing though but its the same as a pugsport item so who knows
Posted 19th Jun 2010 at 20:27
khj100
What makes you unsure? Do you have any specific experience? Surely if it's the same as the pugsport item then it's probably well tested and proven
Posted 19th Jun 2010 at 20:28
lotek
im looking at adjustable top mounts.
what is a ideal amount of camber for occasional track work?
is it like 3deg?
dontthese mounts onlyofferlike 1 degree? Unsure
Posted 19th Jun 2010 at 22:59
is it like 3deg?
Depends on tyres, road rubber will get torn up pretty quick with 3 degrees. Always a bit of a compromise when trying to find a balance between road longevity and track performance.
Posted 19th Jun 2010 at 23:30
velar
These should give around 2 to 3 deg depending on the ride height you run.
Posted 29th Jun 2010 at 02:06
