Author Subject: 106 Brake light
fletch
Track Head
I don't appear to be getting any power to the drivers side rear brake light any more on the 106.
Ive tested the circuit board and get 12V for the rear lights but nothing for brakes. I also tested the plug and get nothing for the brakes.
Likely culprit?
Thanks
Posted 4th Jun 2010 at 13:44
are you testing across the board/pins or from the board to earth?
l/h brake light and high level if fitted ok?
its a common earth for the other bulbs in that unig, so if they are totally unaffected it'll be a break in the wire somewhere, the 106 looms split to either side of the car behind the front seats under the carper IIRC.
Posted 4th Jun 2010 at 13:48
fletch
Track Head
Board was tested using the earth on the board.
Plug tested with an earth in the boot.
Other bulbs ok, find it weird there would be a break in that particular wire.
Posted 4th Jun 2010 at 14:02
