Author Subject: running temperatures
bluesixxer
an easy one for everybody... recently acquired the car and was wondering if the temperatures it runs at are right, i believe the car has been stood a while altho it has a new radiator, fitted up on perchase... the range of water temps it runs at vary from 75c - motorway - all the way upto 95c in traffic (the traffic cleared at this point)... this seems quite a big range to me... oil sat at 90c, never moved... will fit a new thermastat regardless... one other thing, what temp shold i expect the fans to come in at?? any feedback much appreciated... watto
Posted 8th Jun 2010 at 02:36
pugjim
Sounds about right to me.
Posted 8th Jun 2010 at 12:49
james_gti6
I had the same question when I bought mine, mine runs in the same bracket as yours, my fan comes on just under 100,
if i dont see you in the mattress il see you in the spring
Posted 8th Jun 2010 at 18:59
psjunkie
yep my last 2 6's have run at this and have always been alright Thumbs up
1997 P1 Gti 6 Charged
Posted 8th Jun 2010 at 19:31
kit
It's what these cars usually run at. No need to change thermo. Fans will kick in around 100. Oil temp won't go above 90 unless there is a problem or you're giving it stick on a track.
Changing the rad for a Nissens alloy unit will slightly reduce the running temp (although, not by much) and they won't corrode, unlike the rubbish rads Pug produced Thumbs up
Racing driver, fighter pilot, astronaut, compulsive liar.
Posted 8th Jun 2010 at 20:18
ghost6
i was just reading through and my oil temp keeps going over 90 and sitting at more like hundred would this be the thermostat?
ghost
Posted 8th Jun 2010 at 20:37
lee_gti6
How old is the oil?
Proud member of the Astor owners club
Team Charged
Swirl pot and silly boost kit for sale
Posted 9th Jun 2010 at 00:24
Rich E Forum Admin
75 is too low. Our cars use an 83 degree thermostat so once warmed up the temperature shouldn't be below 80 really. I suspect you have a leaking thermostat, most likely due to the seal rotting.
edit: The upper ranges of the temperatures you are seeing sound normal though Smile
Posted 9th Jun 2010 at 03:10
allesclar
agree with Rich E
Team allesclar ®
Posted 9th Jun 2010 at 03:06
dented_vts
Would the thermostat leaking like you say be enough to cause a noticeable drop in coolant?
Posted 10th Jun 2010 at 15:49
