All of the tubes from my Eazibleed kit have disappeared since the last time I used it and I don't want to buy a complete new kit if I can avoid it.
| Author | Subject: Bleeding tubes |
brendanm
Newbie Location: Bristol Registered: 05 Aug 2009 Posts: 28 Status: Offline |
Does anyone know what size tubing is needed to fit on the nipples to drain the fluid from them and where can you can buy them?All of the tubes from my Eazibleed kit have disappeared since the last time I used it and I don't want to buy a complete new kit if I can avoid it. |
cwspellowe
Seasoned Pro Location: Calderbank Registered: 19 Jul 2009 Posts: 6,496 Status: Offline |
I just went to an aquatics shop, found some tubing and went "aye, that'll do"f*ck paying £20 for an easy bleed kit ![]() ________________________________________ Bye bye Sundance Kid |
I bought a reel of washer jet hose from Halfords, cost about £4 for 5 feet and seems to do the job nicely.________________________________________ Membership expiring soon, get in contact on our new little forum project. |
I usually just use the cheap tubes from a local motor factor, about £3-4 or so, they have a one way valve on the end, or a more expensive version at about £6 or so comes with a square pot.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
pugmarshall
Regular Location: Herefordshire Registered: 02 Feb 2009 Posts: 187 Status: Offline |
I don't use any. |
lotek
Seasoned Pro Location: Berkshire Registered: 04 Dec 2007 Posts: 6,107 Status: Offline |
so how you gonna know if the air bubbles are out? ??? |
pugmarshall
I DONT! |
NHS silicon air mask tube ![]() ________________________________________ - Bespoke rollcages/additions/adjustments. Half cages right up to complete custom spaceframes - MSA/FIA spec, CDS, ROPT, T45, etc - PM meEmail me! Custom-made polybushes available - need an odd size or fitment? - anything from batch work to one-off pieces. |
phillipm wrote: NHS silicon air mask tube ![]() I can just picture you creeping through the wards in the dark with your stanley knife, nicking some poor buggers air hose! ________________________________________ R H Davey Welding Supplies. I sell new and used welding equipment in the Hampshire area. I take on welding jobs in the evenings, ally casting repairs are one of my specialities but I can weld pretty much anything. PM me with your requirements.Some of my services: (See my for sale threads) Engine mount/chassis repair Solid Beam Mounts BACK IN PRODUCTION Harness bars |
brendanm
owain wrote: I bought a reel of washer jet hose from Halfords, cost about £4 for 5 feet and seems to do the job nicely. The washer jet hose that they had in stock was of too small a diameter. In the end I got some fuel line pipe from an independant car spares shop as it was closer than any aquatic centres that I could find. I will just have to watch for the bubbles in the fluid. |
I used go-kart fuel hose, nice and soft and flexible.________________________________________ R H Davey Welding Supplies. I sell new and used welding equipment in the Hampshire area. I take on welding jobs in the evenings, ally casting repairs are one of my specialities but I can weld pretty much anything. PM me with your requirements.Some of my services: (See my for sale threads) Engine mount/chassis repair Solid Beam Mounts BACK IN PRODUCTION Harness bars |
daveyboy wrote: phillipm wrote: NHS silicon air mask tube ![]() I can just picture you creeping through the wards in the dark with your stanley knife, nicking some poor buggers air hose! ________________________________________ - Bespoke rollcages/additions/adjustments. Half cages right up to complete custom spaceframes - MSA/FIA spec, CDS, ROPT, T45, etc - PM meEmail me! Custom-made polybushes available - need an odd size or fitment? - anything from batch work to one-off pieces. |
gilesy
Seasoned Pro Location: Greenwich - in that London Registered: 03 Apr 2006 Posts: 5,133 Status: Offline |
daveyboy wrote: phillipm wrote: NHS silicon air mask tube ![]() I can just picture you creeping through the wards in the dark with your stanley knife, intefering with pensioners |
allesclar
Seasoned Pro Location: Sheffield Registered: 17 May 2009 Posts: 4,254 Status: Offline |
SIMPLE.get a jam jar, empty of course ![]() fill it half way with brake fluid. get a pipe like one from a fish tank and tighten it up against the caliper nipple. put the other end in the jar making sure its at the bottom with brake fluid above it. undo the bolt and get a friend to pump the brake. while you keep an eye on the resouvoir, making sure it does not go too low. look at jar as they push the pedal, if no air bubbles come out, job sorted. the brake fluid already in the jar stops the brakes from sucking air back in, it will suck the brake fluid up between pumps on the brake ![]() f*ck paying for something so simple ![]() ________________________________________ Team allesclar ® |
