Author Subject: Thermostat housing
sixygti2
So whilst trying to bleed the system I came to tighten up the thermostat bleed screw and "snap"!
So today got a thin drill bit and tried to wind it out. Unfortunately the tip of the drill snapped and dropped through the tiny hole in the screw and into the thermostat! Roll eyes
I havent started the engine yet as I was worried this tiny little bit of metal might cause some internal damage Unsure
Is it worth getting out, and how would you go about doing that?
Still watching you...
Posted 23rd Jun 2010 at 23:46
take the thermostat elbow off, the plastic bit with 3 nuts/bolts.
a normal M6 caphead screw will suffice till you can get a replacement bleed screw from Puegeot/citroen/scrapyard.
1306 29 DRAIN SCREW DIAM 6X100-18
1339 78 DRN SCR GASKET 10X6,2
princely sum of £1.03.
next time don't do it so fking tight Razz
Posted 24th Jun 2010 at 00:05
sixygti2
I did remove that part way, at least enough to swivel it around but it didnt look like you could actually get into the housing itself!?
Posted 24th Jun 2010 at 00:09
did you pull the thermostat out? LOL
Posted 24th Jun 2010 at 00:31
sixygti2
Doh
Laugh my ass off
How about I give that a go eh!? Should that just pull straight out?
Anyone have a Dunce hat? Laugh
Posted 24th Jun 2010 at 00:45
yup Razz
Posted 24th Jun 2010 at 01:15
I've got a spare thermostat housing with the screw if you need one very cheap. Its a rallye one though.
Posted 24th Jun 2010 at 01:24
sixygti2
Ok mate, will keep that in mind! Thumbs up
Laugh thanks welshy
EDIT: and thanks again as I've only just seen the parts you added to your other post! Merci!!!Happy
Posted 24th Jun 2010 at 05:21
