Author Subject: cylinder head
reggyboy
Does anyone know of any major problems when taking off skimming and replacing cylindr head on 306 gti 6
Posted 30th Jun 2010 at 12:28
Just have a look around mate - there are quite a few potential pitfalls. You can't skim them much and you have to be very, very careful not to bend any valves or valve guides. Plenty of info on here but you'll have to look for it. Might be an article in the FAQ section as well.
Posted 30th Jun 2010 at 13:26
reggyboy
Skimming head because head gasket has gone so what is max skim on these.
The only thing not sure about is the injection system as iv'e not worked on these before is there any major probs with these or is it straightforward as per Haynes manual?
thanks
Posted 30th Jun 2010 at 15:21
ablister
H should be 137 ± 0.05 to 136.8 ± 0.05
306 rallye, Richard Longman engine
rc10gt
Posted 30th Jun 2010 at 23:57
dr-evil
^^^ Life saver - cheers buddy Big grin Thumbs up Thumbs up
Cad Monkey will work for chocolate biscuits....I'm not kidding
Posted 23rd Jul 2010 at 00:11
that picture is of the MI16/S16 head, is that 100% the correct dimension?
Posted 23rd Jul 2010 at 00:15
ryangti6
My main advice would be do not rotate the cams seperatly as this seems to be a very common mistake people make. Other than that its the same as any other headgasket change/skim really
When pinned the cams are locked at the point where some valves are open and if you remove the pins the cams will move and the valves can hit each other(inlet/exhaust) so be very carefull.
Also I dont know if you are aware that ideally you need to remove the exhaust manifold as it is very tight and you could easily hit the valves that are held open
Hope this helps
Ryan
Posted 23rd Jul 2010 at 01:06
