Author Subject: fitting terminal posts to odyssey batteries
gti-dan
Finally received my odyssey battery today but it does not have any terminal posts fitted. I beleive this is because it's main use is as a motorbike battery.
It is an Extreme 25 PC680. I know there are a few people on here running similar batteries / Powervamp / Varley etc.
How have you connected up to these batteries?
There is currently just a 6mm threaded hole for each terminal.
I'm thinking it will be a case of getting the right m6 bolt welded onto a normal battery termainal and fitting them?
Anyone on here make them????
Cheers,
Dan
Posted 3rd Jul 2010 at 15:12
chris with a pug
cant you just cut the terminal off and reterminate with an 6mm ring connector
Posted 4th Jul 2010 at 17:31
gti-dan
yeah i suppose. There would be 3 to do off the negattive terminal though and i'd probably have to lengthen them as they only just reach the battery now.
Posted 4th Jul 2010 at 19:21
