displaying posts 76 to 100 of 520
Pages (21): first .. 3 [4] 5 .. last
Author Subject: Diablo Track Toy
blaze wip
Post #76
eddy_gti6 wrote:
blaze wip wrote:
eddy_gti6 wrote:
i will have a run up sometime rob. i will sell you her back if you want rob LOL £200000000 Razz nahh its not for sale i like this one to much Big grin
Is that all?! LOL
Which garage is it at mate?
My mate works at SMC in Stanley, it tends to be more Audi's & VW's but he's a tester too so i could get him to take a look if you want?
When you had the rear brakes done did you get a new bleed nipple in the offside? It needed one, sealed up ok but was rounded to f*ck.
by any chance it wasnt the driverside that rounded off was it? i didnt do the brakes last time, my mate done the pads and pressure bleeded the system but there is still air getting in somewhere.
Aye mate, drivers side / offside / same difference.
Are the brakes getting progressively worse? As in like there was a leak for air to enter, or does it just not feel right at all?
Can the bias valves hold any air? I think that one is seized, bash it with a hammer after a good soak in plusgas and when it's freed off, bleed the system again.
mechanical_repairs wrote:
i feel like giving her a good dry bumming session.
Posted 6th Aug 2010 at 03:57
eddy_gti6
Post #77
there is air getting into the brake system somewhere. dont no if the bias valves can hold air on not? its somewhere from the abs pump to the rear caliper that the air is getting in.
Posted 6th Aug 2010 at 04:03
eddy_gti6
Post #78
This weekend i have been up in Perth, had some track time at knockhill on Sunday with chrisd306. Had some time on Saturday to sort a few things on my car.
Got my car up on the ramps to make a start, had an advisory sheet from my mot what said i needed a new n/s ball joint, checked both ball joints and there was no problem, problem we found was o/s wheel bearing. Chris cracked on with changing my hub as he had a spare while i fitted new hand brake cable and Gmax rear shocks and removed my spare wheel and hanger. Also had his dad weld my exhaust up and fit me a new exhaust hanger.
After knockhill i headed back up to Perth with Chris to pick up my new wheels Big grin not sure weather to paint then the same colour my cyclones were or to leave them how they are?
Posted 23rd Aug 2010 at 23:57
mike rallye
Post #79
lookin very nice, i like the wheels how they are now Thumbs up
Posted 24th Aug 2010 at 01:41
jimmyrallye
Post #80
+1 dont go oriental with the spray can again leave the wheels as they are , 6 is comeing along nicely .
Posted 24th Aug 2010 at 02:08
Post #81
Wheels look shit Wink
Posted 24th Aug 2010 at 02:24
eddy_gti6
Post #82
why did you want them then??? Razz
Posted 24th Aug 2010 at 12:18
eddy_gti6
Post #83
had a bit of a problem lastnight on my way home, i last all power and then started throwing loads of white smoke out the back, and i mean loads. the engine was a tapper but now its even louder and struggles to start. i am thinking head gasket but anyone think any different?
Posted 26th Aug 2010 at 12:54
turbowagon
Post #84
wheels look gd as they are
slowest project car ever.com
Posted 26th Aug 2010 at 23:07
eddy_gti6
Post #85
Just gone and picked my car up from my mates, drove it home and there was a hell of alot of white smoke coming out the exhaust, filled the roads LOL tapping has got alot worse aswell. i am hoping its just the headgasket because i have had enough of rebuilding gti6 engines now Sad
i have a spare head in my shead with 16 bent valves. removed the cams to get to the valve buckets, when you press down on them should they be solid or should they have abit of a spring on them? 10 of them dont budge and the other 6 i can press down a little bit
Posted 27th Aug 2010 at 00:39
mjm3043
Post #86
They should be solid. Will go soft over time if left sitting. But ater the engines being run should be soild. Could possible be what your tapping sound is.
Posted 27th Aug 2010 at 00:46
eddy_gti6
Post #87
wound it just be a case of new Hydraulic tappets or what? i will hopefuly get time to check the head on my 6 this weekend
Posted 27th Aug 2010 at 00:53
mjm3043
Post #88
Yeah think new ones would be the best way forward.
Posted 27th Aug 2010 at 00:57
jimmyrallye
Post #89
another eddy 6 that has gone to the graveyard , bad times fella , you should just buy one that dosent tap or need engine work , as i had no engine trouble at all with my 6 or rallye
Posted 27th Aug 2010 at 01:03
eddy_gti6
Post #90
i no, i realy want a rallye Love
things just keep getting worse. i dont think its my head gasket, just checked my oil, its now below the lowest mark, exhaust is covered in oil, water is fine and it sounds like a scooby. think its a piston ring. going to check the plugs tomorrow and see what one it is, i have a spare block but its off my old 6 and the bottom end is sized so hopefuly 2 bottom ends will make one good one then that just leaves the tapping head to sort out. this one will not be going to the grave yard, i Love it too much at the minute LOL i only broke the old 6 because it needed to much work doing Sad
Posted 27th Aug 2010 at 02:18
chrisd306
Post #91
its to do with a slight bend in a valve thats why it taps im sure, get a 10k loan buy my wallye
In my garage just now
& Audi Q5 S Line
AX stock rod & Saxo Stock rod
Posted 27th Aug 2010 at 03:08
jammamayhew Banned!
Post #92
I prefer the second set of wheel than the cyclones in the colours given, however I think cyclones look awesome standard and you should put standard cyclones back on Smile
JAMMA "M44YHW" MAYHEW
LOSE WEIGHT NOW - ASK ME HOW -
NUTRI-FIX
GTi6 LPG, The best of both worlds!
2006: 1997 R reg 306 1.4 Miami - Diablo Red - DEAD
2007: 1999 V reg 306 1.4 Meridian - Diablo Red - SOLD
2007-09: 1998 S reg 306 GTi6 - Diablo Red - DEAD
2009-10: 1998 R reg Corsa 1.2 - Blue - SOLD
2010-13: 2001 Y reg 306 GTi6 LPG - Diablo Red - DEAD
2013 - 2013: 2000 X reg GTi6 LPG - Moonstone Blue - DEAD
2013 - current: 2001 X reg GTi6 LPG - Diablo Red
]FOR SALE[/b]
"I LIVE FOR THE 306"
Posted 27th Aug 2010 at 03:11
eddy_gti6
Post #93
no, i like the oz wheels i have now, they look Cool
my engine will be getting stripped down next week so i will check the valves ald let you no if thats what it is chris. you have a full set of good valves dont you?
Posted 27th Aug 2010 at 03:35
chrisd306
Post #94
yeah but i should have 2 sets mate, check my project edd
& Audi Q5 S Line
Posted 27th Aug 2010 at 03:37
eddy_gti6
Post #95
not want to sort me a set out? i could do with some for my spare head as all the valves are bent from when my belt slipped on the last 6
Posted 27th Aug 2010 at 03:43
eddy_gti6
Post #96
today i stripped my spare sized bottom end down and found the problem with it, the shells on piston 4 were f*cked and had worn down the crank so would need to be reground and new shells fitted. i may be able to save my other bottom end, hope its just a piston thats the problem.
also after work i removed my plugs to see if any of them were covered in oil. this is what i found, plugs 1, 2 & 4 were black and plug 3 had no end on it. something has been hitting it some how to chew it up like this. going to get a better look at it next week when i get my engine out.
Posted 28th Aug 2010 at 02:38
blaze wip
Post #97
F*cking hell Chris!
Looks like a little more than the HG then! Sad
Posted 28th Aug 2010 at 02:43
eddy_gti6
Post #98
yeah. good job i have plenty of spae parts LOL
Posted 28th Aug 2010 at 02:44
Post #99
Just break it and buy my rallye Wink
Posted 28th Aug 2010 at 03:09
eddy_gti6
Post #100
thought you were keeping it now?
swap you for my wheels Razz
Posted 28th Aug 2010 at 03:13
