displaying posts 151 to 175 of 520
Pages (21): first .. 6 [7] 8 .. last
Author Subject: Diablo Track Toy
eddy_gti6
Post #151
there are a couple of little chips in the bore but nothing big. i wont be using that block for my rebuild tho. i will get a better look at it today once i get the whole lot stripped down. i found chunks of piston and the valve seat inside my inlet manifold and sump. all i need of this block is the crank if its ok
Posted 4th Sep 2010 at 15:36
eddy_gti6
Post #152
been on all day stripping both my bottom ends down and making up one good one. striped the 1st one down whet has the hole in the piston, all i needed was the crank and shells, once i got them out and checked them they were all fine, not a mark on them. started with the 2nd bottom end what had sized big end bearings on conrod 4. stripped it down, removed crank and shells ande gave all the bits i was going to use a good clean. built the block back up with bood shells and crank, torqued them down to what it said in the book
big end: 25nm then a further 70degree turn
main bearings: 20nm then a further 60degree turn
put everything else back on, oil pump ect... and it wouldnt turn over by the crank pully. so i took it all apart again re tightend all the bolts and put it back together and still no joy Sad
think am just going to buy a new engine and save the hassle on. Angry
Posted 4th Sep 2010 at 21:38
CUJ
Post #153
I've just done exactly the same thing, with the help of Welshpug and Ash. Hope you get there mate, that piston was a mess Mellow
I'm sure it's something simple why it isn't turning, I'm afraid I don't the knowledge to advise though.
340 horses
Posted 4th Sep 2010 at 21:42
eddy_gti6
Post #154
has to be something simple, maybe over tightend a bolt or something? lost interest now so will leave it for another day
Posted 4th Sep 2010 at 22:58
Post #155
eddy_gti6 wrote:
think am just going to buy a new engine ash's rather lovely rallye and save the hassle.
EFA!! Thumbs up
Posted 4th Sep 2010 at 23:36
mjm3043
Post #156
did you keep the caps for the crank on the same block and in the same order, if not thats why its locked up.
Posted 4th Sep 2010 at 23:45
eddy_gti6
Post #157
yes, removed all shells, placed them in order of where they came from and put them back in the same place.
swap for my 6 and 2 broken engines ash Thumbs up
Posted 5th Sep 2010 at 00:16
Post #158
Laugh my ass off you missed out the 2k in the deal
Posted 5th Sep 2010 at 00:19
Post #159
did you use the original crankcaps from the same engine? or the ones from the other block?
new piston rings?
Jon's engine was very tight due to the new rings, but still turned over fine with a spanner.
Posted 5th Sep 2010 at 00:22
Post #160
Check the main caps are all in the right way round, not just in the right numerical order, they will fit both ways round and when you torque the caps up it nips the crank. I've done this before.
Posted 5th Sep 2010 at 00:28
chrisd306
Post #161
I done that to mate used caps from a diff engine and it locked up used the orginal ones and it was fine
In my garage just now
& Audi Q5 S Line
AX stock rod & Saxo Stock rod
Posted 5th Sep 2010 at 19:17
eddy_gti6
Post #162
yeah, used the crankcaps from the engine i got the crank from. so if i use the crankcaps from the block i am using now they should be fine? i will give it a go tomorrow. hopefully my new head should be here tomorrow so i will get may dad to strip that down for me if he has nothing else to do LOL
Posted 6th Sep 2010 at 04:22
eddy_gti6
Post #163
well get the crankcaps swapped over today, engine turns over just fine Big grin thatks for all the advice Thumbs up just waiting on my head turning up now so i can get that sorted and put back together.
decided to fit my battery cut off switch aswell. not got if on the car you but this is how its looking so far, i was going to put it on the inside of the car but couldnt fand anywhere to put it so i got the idea from the BTCC cars and put it just beneath the windscreen.
sorry about the pic quality, i will get better ones tonight once i have fitted it to the car
Posted 7th Sep 2010 at 12:18
eddy_gti6
Post #164
recieved my new head today. made a start on stripping it down and cleaning it up. managed to get the cams out and used some petrol to clean all the shit from underneath them. need to strip my head down tomorrow to get my cams as the ones in the head i have just getten aint in the best condition. all valves look fine and fully close. once i get the head built i get get the engine back together Big grin
you can see the difference where i have cleaned one side of the head
Posted 8th Sep 2010 at 02:27
Post #165
crikey I hope that was cheap!
Posted 8th Sep 2010 at 03:12
eddy_gti6
Post #166
try befor you buy Razz friend helping a friend in need Thumbs up chrisd306
Posted 8th Sep 2010 at 03:26
chrisd306
Post #167
it was free untill he see if it works or not, it was erm stored outside my garage dunnno why it wasnt inside it!
& Audi Q5 S Line
Posted 9th Sep 2010 at 00:29
eddy_gti6
Post #168
changed the valve the valve caps today and fitted some different cams out of my old engine. decided to give the head a lick of paint to tidy it up aswell while i have it out. next job is to get a head gasket and get the engine back together at the weekend at the latest i hope.
Posted 10th Sep 2010 at 03:48
eddy_gti6
Post #169
engine is on the rebuilt, been on painting afew parts today and putting everything back on the bottom end. also got all my new stainless bolts today from mr swampy s16 Thumbs up also just ordered some AeroCatch Plus Flush Locking bonnet catches so they should be here next week
Posted 10th Sep 2010 at 03:08
tea boy
Post #170
eddy_gti6 wrote:
decided to gove the head a lick of paint to tidy it up aswell.
You not finished that tin of red paint off yet?Roll eyes Big grin
Make tea, not war.
If it ain't broke......fix it until it is.
Posted 10th Sep 2010 at 03:40
eddy_gti6
Post #171
no, not yet LOL how did you no it was going to be red? done the bottom end today but that went black and gray Big grin found a new favourite colour
block, head gasket and new bolts
Posted 13th Sep 2010 at 01:18
chrisd306
Post #172
somebody take that f*cking rattle can of him!!
& Audi Q5 S Line
Posted 10th Sep 2010 at 16:43
jimmyrallye
Post #173
^^^LOL hes ruthless with that can
Posted 10th Sep 2010 at 19:38
eddy_gti6
Post #174
got to look good under the bonnet Cool
Posted 10th Sep 2010 at 22:02
chrisd306
Post #175
thought you were going to be smoking the tyres this weekend, or was that just shite you were writing on facebook christoph?
& Audi Q5 S Line
Posted 12th Sep 2010 at 06:53
