displaying posts 1 to 2 of 2
Author Subject: temp
reggyboy
is it right that the fans don't kick in until 105c?
Coz when i was checking if the fans were working after seeing the water boiling i switched the engine off!
Posted 19th Jul 2010 at 22:05
cosmic spanner
Moral objector
The fans should kick in at low speed at approx 97*C and then high speed at approx 105*C!!
If one of the fan motors/wiring/relays is faulty, you lose low-speed mode and therefore you just have the one fan running in high speed mode. But that should still be enough to keep it out of the red (Rallyes only have the 1 fan anyway) unless something else is wrong..
Try disconnecting the brown CTS on the thermostat housing, check to see both fans running at high speed.. Either way, there's a guide to the cooling fan system in the FAQ section.
Democracy is two wolves and a lamb voting on what to have for lunch..
..Liberty is a well-armed lamb contesting the vote.
Project é - my 306 project thread.
Posted 19th Jul 2010 at 22:32
