Author Subject: what would happen if...
noaki
what would happen if i wacked a gti6 inlet/exhaust manifold, gti6 ecu, power boost valve, bigger fuel injectors, k&n air filter, stright thru pipe with a custom powerflow box and remap a standard xsi? .. didnt know what to class this as and this seems the best overall page Razz cheers ( its all going on my mates xsi NOT mine)
Team ex "manstone" - "THATS TO LOW!!"..."I KNOW!" Sad
Team defeat - bring on the *06! :/
Posted 29th Jul 2010 at 05:42
you'd need the gti6 cams, but then you'd be pretty damn close to gti6 power.
also you'd need to drill a hole in the casting on the head next the inlet cam pulley and tap a small hole to accept the cam sensor.
don't bother with the power boost valve, all they do is waste your money.
Posted 30th Jul 2010 at 00:00
noaki
ok i wont bother with it then lol just a thort .. so what kind of power will i have ish without the cam?
Posted 30th Jul 2010 at 16:09
Surely cheaper and easier to just source a gti6 engine with loom and unlocked ecu?
Posted 30th Jul 2010 at 16:22
EFA Thumbs up
Whistle
Ninja
Posted 30th Jul 2010 at 21:53
bobdylan_55
as above. dont waste your money on the xsi.
309 GTi6-T
Posted 30th Jul 2010 at 21:58
noaki
you see I would but I'd like to see your w plate 306 with 18k on the clock... Good old gramps Big grin
Posted 31st Jul 2010 at 01:54
bobdylan_55
then just put an entire gti6 engine in. You can pick them up for about £200 which is probably what itll cost you to fit half the parts listed above with no gaurentee of it being as powerful as a gti6. Will also be much easier and quicker.
309 GTi6-T
Posted 31st Jul 2010 at 02:14
cwspellowe
Plus for insurance it'll be cheaper to insure a car quick as standard as opposed to insuring a modified car to the same spec. Plus there's the hassle of getting an engineer's report etc for switching the engine.
That is, if he IS going to declare it...
Bye bye Sundance Kid Sad
Posted 31st Jul 2010 at 02:16
noaki
so your saying it will just be cheeper to fit a '6 engine? but wouldnt that still class as a modded car even if i fit a stock engine? Sad
Posted 2nd Aug 2010 at 05:14
