Author Subject: "death clutch"
noaki
right what the hell is going on my clutch is hard as anything to the point of me brakeing my seat trying to change geer.. slots into gears easily but fook me my leg hurts in start stop traffic now i no this is a common thing to live with if you have a 306 but im fed up if it! how can i make it not so stiff!
Team ex "manstone" - "THATS TO LOW!!"..."I KNOW!" Sad
Team defeat - bring on the *06! :/
Posted 29th Jul 2010 at 06:09
Have you tried removing the spring clip from behind the peddle?
Posted 29th Jul 2010 at 07:03
noaki
no but i will do.. but if its not this?
Posted 29th Jul 2010 at 07:27
I'd say maybe your clutch cable maybe but that's one of the worst jobs to do on the 6 especially if you have aircon pipes be prepaired for lots of shouting and swearing and maybe some skin loss if that didn't fix it then new clutch I'd just try ride it out if that clip does nothing it's supposed to help pull you peddle down but a lot of the time seems to make life harder
mine runs fine without it Wink Thumbs up
Posted 29th Jul 2010 at 08:23
gilesy
Chances are its your cable, not too hard to do once you have your hand in the right bit, your head in the right position and a bit of courage!!
I have changed 2 now, first one by myself, f*ck me what a job. If you can get someone to give you a hand, its soooooooooo much easier, otherwise you need to keep getting out from under the car to pull the string/cable through the hole of death!
Look at the FAQ, good guide in there.
Posted 29th Jul 2010 at 14:24
tubbyrutter
Man up.
Renault Megane Renaultsport 230 F1 Team R26 Blink
Posted 29th Jul 2010 at 15:10
New clutch and cable will sort it mate, and make sure you buy new fork arm bearings at the same time and grease them up when fitting them....Makes the clutch uber light then. Big grin
Stan.
Posted 1st Aug 2010 at 17:02
