Author Subject: engin idling high
:: blade ::
hi all, just wondering why my car has decieded to idle funny, its revs on its own for abit, and doesnt go below 10k revs, i have changed the throttle body for one i ported and polished, but a have checked and there is no airleaks, what else could it be?
click me for the vid
hope you can shed some light,
cheers
Iain
Black Ph1 XSi-6
161.8BHP (Getting Better!!!!)
Posted 10th Aug 2010 at 00:46
stick the old throttle body back on see what happens.
Posted 10th Aug 2010 at 01:03
lwgti-6
Have you adjusted the accelerator cable adjuster on the throttle body at all?
EX Bianca 6 owner,
Now drives: Octavia vRS
Posted 10th Aug 2010 at 02:31
:: blade ::
nope its how it was before i changed the throttle body,
Black Ph1 XSi-6
Posted 10th Aug 2010 at 02:32
simonjames
Adjust so cable is longer and all should be fine
MY EBAY ITEMS
07943066306
Posted 10th Aug 2010 at 02:42
:: blade ::
i can take the throttle cable out and it will be the same tho
Black Ph1 XSi-6
Posted 10th Aug 2010 at 02:41
simonjames
Has the little grub screw been adjusted to push the linkage open?
MY EBAY ITEMS
07943066306
Posted 10th Aug 2010 at 02:43
:: blade ::
which grub screw be this? the one on the butterfly in the throttle body?
Black Ph1 XSi-6
Posted 10th Aug 2010 at 02:44
simonjames
1 by the linkage that the cable attaches too
if you disconnect the cable from linkage is it the same? can linkage be moved closed I.E sticking open but can be manually closed
MY EBAY ITEMS
07943066306
Posted 10th Aug 2010 at 02:47
:: blade ::
nope if i take the cable out it will idle the same, and the linkage moves freely, doesnt stick anywhere
Black Ph1 XSi-6
Posted 10th Aug 2010 at 02:48
simonjames
ICV sticking?
seems strange tbh
MY EBAY ITEMS
07943066306
Posted 10th Aug 2010 at 16:53
dubious porting work probably...
Posted 11th Aug 2010 at 01:09
bristolxsi
mind does this as well and been trying to find the problem for ages i had a new ICV straight from pug and didnt cure the issue.
Posted 13th Aug 2010 at 04:13
smegal
Make sure the throttle body springs fully closed.
Ex SC-6
Now in a Megane R26
Posted 13th Aug 2010 at 04:33
:: blade ::
I seem to have fixed it. Car seems to rev a little faster with this throttle body, all i have done is unplug the map sensor and plug it back in, going to take the ICV out and clean that next week and see if that sorts anything Smile will keep u posted.
Black Ph1 XSi-6
Posted 14th Aug 2010 at 00:55
bristolxsi
Where is the MAP Sensor to on the engine?
Posted 15th Aug 2010 at 19:05
