Author Subject: Cylinder head removal
kriz5176
Having looked at all the threads on removing the cylinder head, there seems to be different opinions on whether to leave the exhaust manifold on or off.The manual in FAQ says leave it on and use an engine hoist to get it out. Is an engine hoist a necessity or can it be manhandled out. My concern is catching the valves on removal or more importantly when putting it back.
chris
Posted 10th Aug 2010 at 22:32
jonnie205
must remove ex manifold in the car, the head will not come out without a massive struggle with the ex manifold left on, if you do attempt leaving it on you will have to undo loads more and it is going to have to be removed on the bench anyway
Posted 10th Aug 2010 at 22:51
kriz5176
If it has to come out in the car - How on earth do you get to the nuts holding it on. The manual says hoist the lot out after lowering the engine a bit.
chris
Posted 10th Aug 2010 at 23:40
Its a f*cker to get to the bolts some can be got from under the car the others from the top you kind of need to kneel on the engine if that makes sense ?
Posted 10th Aug 2010 at 23:43
the only one I found difficult was one that had rounded off Doh
I used a snapon 3/8 ratchet and 6 sided socket.
did all of them from the top.
Posted 11th Aug 2010 at 01:07
rallyeash
fun and games undoing them manifold bolts, some from the top kneeling on the engine with your head burried down by the bulkhead others underneath with extension bars...
309 3dr K20 Type R
Posted 11th Aug 2010 at 01:08
jeffers Forum Admin
Rachet ring spanner from the top will remove all exhaust mani bolts and the head will come off, trust me i've just done it on my drive its not that difficult at all!, Just make sure you remove the exhaust cam cover and heat shield, it makes access easier!Wink
Team Running Engine again!
Team Negative Camber!
Posted 11th Aug 2010 at 01:58
kriz5176
Thanks for all the replies. Off in the car it is then. Have to get a ratchet ring spanner now. Do i remember reading somewhere that it is a 13mm?
chris
Posted 11th Aug 2010 at 02:07
Yes, 13mm....
Posted 11th Aug 2010 at 02:25
jeffers Forum Admin
It is, halfords do a professional set (lifetime guarantee) for about £40 for 10-19mm Well worth it imo!Cool
Posted 11th Aug 2010 at 02:26
kriz5176
Thanks for your help. I'll let you know how I get on, and no doubt want more help
chris
Posted 11th Aug 2010 at 02:39
joevts
or about £12 for the 13mm on its own if you're a tight git like me LOL
Posted 11th Aug 2010 at 14:33
jeffers Forum Admin
LOL
Posted 11th Aug 2010 at 20:20
mikebee
Sorry to drag up an old thread. Will be taking the head off mine next weekend. It says in the Haynes book of lies to be very careful removing the head due to the wet liners.
Is there anything else like this I need to be wary of? Good tips of getting the exhaust manifold off btw, makes this place massively useful!
Posted 19th Sep 2010 at 15:12
wet liners is the alloy block, you've been reading the wrong section LOL
the main point you have to be very careful of is not knocking any of the valves on the block as you lift off the head, it weighs about 30 kilos so best to have some assistance.
have some card and a clean space to put the head down on its side, not on its face.
Posted 19th Sep 2010 at 15:18
mikebee
Oops Whistle
Posted 19th Sep 2010 at 17:33
