Author Subject: clutch pressure plate
papa
Bolts on pressure plate to flywheel siezed, any ideas.
Posted 15th Aug 2010 at 00:10
use bigger bar Thumbs up
Posted 15th Aug 2010 at 00:13
greenbelt
Does the flywheel need to be locked to undo the bolts and if so, what do you use?
Standard Black 6
Black HBSC6 Smoke
Posted 15th Aug 2010 at 00:39
I just use a draper Allen key bit from the set and a 3/8 ratchet, if needed I use a big screwdriver to hold the flywheel.
Posted 15th Aug 2010 at 01:07
greenbelt
Cheers Thumbs up
Standard Black 6
Black HBSC6 Smoke
Posted 15th Aug 2010 at 01:18
Teamwork makes the dream work Wink
Posted 15th Aug 2010 at 16:55
chris with a pug
Have you tried an Impact driver? that should get them to move. If not Just grind or drill the heads off then the threads will just screw out as the pressure on them is gone (we had to do this on a few of Daveyboys ones)
Posted 15th Aug 2010 at 15:40
papa
Thanks for your suggestions but my final solution was a bit unorthadox. On two of the bolts the torx bit would not hold and was starting to chew the nuts. I used a scissor jack against the inside wing applying pressure to the ratchet and torx bit and hey presto!
Posted 17th Aug 2010 at 22:58
err, all I've ever seen used is a 6mm allen or a 13mm AF headed bolt!
so I may not be surprised at all that a Torx bit slipped LOL
Posted 18th Aug 2010 at 00:08
papa
Well I'm not surprised that your not surprised but suprise, suprise it worked.
Posted 18th Aug 2010 at 00:23
