Author Subject: 406 Brembo with 307 XSI discs
FatBastard
Hi all,
I was wondering if instead of fitting 406 brembos with 288mm xantia discs i can fit the 307 xsi 302mm discs. I have 16" wheels.
307 XSI specs
Xantia V6 specs
306 GTI6 specs
Posted 16th Aug 2010 at 18:34
bellcp306td
You might be able to but it will not be bolt and go you will have to make some adapter bracket for the Brembos. RS Brembos and a kit from Ash is way! better.
Where did the road go!
Posted 16th Aug 2010 at 20:14
FatBastard
But It seems that the 307 offsets are closer to the 306 offsets than the xantia ones.
getting calipers in my country is almost impossible and i do have the 406 brembos, so i cant afford Ash's kit, even though i would like that.
Posted 18th Aug 2010 at 18:18
But the xantia offset disc works with the 306 hub and the offset on the 406 calipers. If you change the disc offset it may not work.
Posted 18th Aug 2010 at 18:58
Rich E Forum Admin
If those drawings are correct then they should fit.
You will need to check the obvious things like space inside the caliper and also bear in mind that the outer pad will need to be 2mm further in than before so check the pistons can still fully extend the pad.
Posted 18th Aug 2010 at 19:11
FatBastard
Ok thanks.
I will update if/when i know those discs fit the Brembos.
Posted 21st Aug 2010 at 04:23
lotek
any joy?
Posted 31st Aug 2010 at 21:21
theyre too big, the radius of the 306+307 mounting lugs is smaller than the 406, so you have to run a smaller disc.
the xantia/C5 discs are perfect, if a tad squealy....
Posted 1st Sep 2010 at 00:02
