1999 Astor Grey GTi-6 OEM+ (now gone...)2004 Aegean Blue 206 GTi 180 (also gone...)
| Author | Subject: High Boost Supercharged Rallye |
matt evans
Seasoned Pro Location: Stourbridge Registered: 16 Sep 2009 Posts: 2,290 Status: Offline |
Post #101
Good work fella!________________________________________ 1999 Astor Grey GTi-6 OEM+ (now gone...)2004 Aegean Blue 206 GTi 180 (also gone...) 2006 Skoda Fabia vRS in Sprint Yellow honestly3k wrote: Do you wrestle for a living matt? You sound like a monster ![]() owain wrote: Nothing involving a 306 can be considered worthwhile. |
eddy_gti6
Post #102
See you at knockhill 15th sep???________________________________________ Clicky: [url =http://www.306gti6.com]click here[/url] remove the space between [url & = |
russbez
Post #103
i am away that week, but doubt i would anywayneed to get house built and funds arent looking great just now ________________________________________ TEAM HIGH BOOST SUPERCHARGED RALLYEMy Rallye project thread |
rich306
Seasoned Pro Location: Portsmouth Registered: 09 Aug 2009 Posts: 1,834 Status: Offline |
Post #104
Well done that looks Rather nice :p ________________________________________ Richies Project RallyeElectrical work carried out in Portsmouth jamiek_uk2000 wrote: - Top Tip!!! You'll need to throw money at the car. Not on parts. Just stand near your car and throw loose change at it, I find this increases performance for a short period of time |
russbez
Post #105
new 6 paddle clutch!!![]() masked off and painted the top bits of the pads where they had been cut to suit ![]() wilwoods cleaned up a bit ![]() ________________________________________ TEAM HIGH BOOST SUPERCHARGED RALLYEMy Rallye project thread |
russbez
Post #106
timing belt and waterpump done![]() Few pictures of chassis after two coats ![]() ![]() ![]() ![]() ![]() ________________________________________ TEAM HIGH BOOST SUPERCHARGED RALLYEMy Rallye project thread |
Post #107
Did you pin the cam pulleys when you did the belt?________________________________________ ![]() |
russbez
Post #108
of course ![]() was a mechanic that done my last cambelt that done it all lined up perfect before and after too ________________________________________ TEAM HIGH BOOST SUPERCHARGED RALLYEMy Rallye project thread |
eddy_gti6
Post #109
everyone is going for wilwoods now good work russ, Keep it up________________________________________ Clicky: [url =http://www.306gti6.com]click here[/url] remove the space between [url & = |
russbez
Post #110
what pads did you go for mate?________________________________________ TEAM HIGH BOOST SUPERCHARGED RALLYEMy Rallye project thread |
eddy_gti6
Post #111
Am selling mine, there no good, the lad i bought them off said they were midilite calipers but there not, there powerlite what only take solid discs! ![]() ________________________________________ Clicky: [url =http://www.306gti6.com]click here[/url] remove the space between [url & = |
Seasoned Pro Location: Southwark Registered: 18 Jul 2010 Posts: 4,865 Status: Offline |
Post #112
Are those injectors not meant to be at an angle like normal 6 ones then?________________________________________ Ex- Phase 3 China GTi-6 T-Reg |
russbez
Post #113
not sure ![]() cant remember how the old ones looked but once i fit the wee clips and i might have to angle the injectors in order to fit the injector plugs on?? ________________________________________ TEAM HIGH BOOST SUPERCHARGED RALLYEMy Rallye project thread |
Post #114
Ohyeah that might be right.. I hate those clips. They are so fiddly. (Probably just me)________________________________________ Ex- Phase 3 China GTi-6 T-Reg |
russbez
Post #115
nope not just you ![]() i couldnt remember what way they go ________________________________________ TEAM HIGH BOOST SUPERCHARGED RALLYEMy Rallye project thread |
russbez
Post #116
![]() ![]() ready for engine now, slowly building everything back up then engine and gearbox is pretty much ready to go in been looking at the front lower chassis legs, can feel there is rust under the stone chip stuff was half planning taking subframe off and derusting the whole lot will do this at later date as i want to get car on the road for a few month before i am snowed in again ![]() ________________________________________ TEAM HIGH BOOST SUPERCHARGED RALLYEMy Rallye project thread |
russbez
Post #117
chassis legs are not corroded as i first thought, minor surface rust gave it a rub with dremmel and painted over with zinc paint. Will sort another timei am missing a bracket that secures the heatshield... i have hunted high and low think i must of not got it back from powder coaters ![]() anyway made a wanted thread for that and now and i do plan to fit engine today still have swirl pot and fuel pump to play with ![]() Engine ready ![]() Engine bay ready ![]() And some more ![]() ![]() ![]() ![]() ![]() ![]() temporary repair by the heat tape, will do until i get something better to replace my heatshield ![]() ________________________________________ TEAM HIGH BOOST SUPERCHARGED RALLYEMy Rallye project thread |
russbez
Post #118
Engines in, started the swirl pot too.![]() ![]() ![]() ________________________________________ TEAM HIGH BOOST SUPERCHARGED RALLYEMy Rallye project thread |
russbez
Post #119
Wiring looms, drive shafts, gearbox oil, brake lines, Wilwoods, new pads![]() ![]() ![]() relay for uprated fuel pump pretty much wired in, havent took enough pictures of the whole setup yet here is where i spliced into loom to use as trigger wire for switching the relay on ![]() ![]() as discussed with some very helpful members on here i used fuse 9 blue wire if anyones interested....wiring thread ________________________________________ TEAM HIGH BOOST SUPERCHARGED RALLYEMy Rallye project thread |
russbez
Post #120
Supercharger back on and bled...![]() ![]() obligatory left over part picture... ![]() more parts on ![]() still trying to source missing exhaust heat shield bracket... ![]() new Antifreeze, steering fluid brake fluid all in had it up and running a few nights ago idled perfect engine sounds okay. ________________________________________ TEAM HIGH BOOST SUPERCHARGED RALLYEMy Rallye project thread |
russbez
Post #121
heater controls are playing up, when i had dash out i replaced them with less worn looking onesi noticed the wire rope that closes my fan flap didnt quiet feel right. (Six and Rallye have different setups iirc) I must of moved something when cleaning the top of the intake flap from the outside. when i go to close the flap completly it stays closed, i managed to pop it back open by pushing the controls under the passenger side of dash. "1 to 4" still works okay for now. Ready to go for test drive... ![]() ![]() ________________________________________ TEAM HIGH BOOST SUPERCHARGED RALLYEMy Rallye project thread |
russbez
Post #122
![]() ![]() ![]() the Wilwoods are in dire need of being bled again, and then again.... highboost but highboost with no brakes.... not soo much love.Helix 6 Paddle Clutch with Saches cover feels ace, very precise ![]() considering iv been driving a 67bhp diesel for past month and a bit i thought the fact i did'nt stall once spoke for itself. ________________________________________ TEAM HIGH BOOST SUPERCHARGED RALLYEMy Rallye project thread |
ed_doe
Regular Location: Milford Registered: 26 Aug 2009 Posts: 255 Status: Offline |
Post #123
Can I just ask why you're running the high-boost set-up with the throttle body pre-charger? I thought high-boost ran with a recirc valve in the charger body, DTA management and the TB on the end of the inlet?________________________________________ '97 Black Dturbo 110,000miles: SOLD'99 Ph3 Diablo Gti6 108k RIP '93 106 1.5n/a d: daily hack YAAAAAWN '00 Ph3 Astor GTi6 117k |
davedgti6
Seasoned Pro Location: whiston, prescot Registered: 28 May 2006 Posts: 1,651 Status: Offline |
Post #124
ed_doe wrote: Can I just ask why you're running the high-boost set-up with the throttle body pre-charger? I thought high-boost ran with a recirc valve in the charger body, DTA management and the TB on the end of the inlet? No that's the super high boost conversion ________________________________________ Team Supercharged Gti-6™![]() |
russbez
Post #125
what he said ![]() mines normal high boost and not "super highboost" which uses a larger supercharger ________________________________________ TEAM HIGH BOOST SUPERCHARGED RALLYEMy Rallye project thread |
