| Author | Subject: engine tapping, need help describing... |
turna123
Junior User Location: burbage Registered: 27 May 2010 Posts: 52 Status: Offline |
Hi, been on here loads and looked at why the 6's tap ( bad cambelt repair) iv tryed to explain this to my mechanic, but he doesnt understand. He says bent valves mean non running engine. What exactly is wrong and why does it tap, and why does it still run? thanks |
its because the valves are only the tinyest bit bent or the valve guides are damaged. Some people only change the visibly bent ones and the others which appear fine still seal ok but tap. After a belt fail all 16 should be changed, valve seats re cut and you'll be lucky if you dont have a smashed valve guide or 2. Hope this helps. Pete.________________________________________ Black power baby! SUUUUUPERCHARGED Seat Leon FR TDI 190BHP 300lbft daily gti-6 killer :p 12x 306's owned so far Cambelts, clutches, service work carried out on All makes and models, Peugeot Citroen / mitsubishi specialist. Pug planet / Citroen Lexia diagnostics / code reads available. |
honestly3k
Seasoned Pro Location: Berkhamsted Registered: 06 Apr 2009 Posts: 2,390 Status: Offline |
turna123 wrote: Hi, been on here loads and looked at why the 6's tap ( bad cambelt repair) iv tryed to explain this to my mechanic, but he doesnt understand. He says bent valves mean non running engine. What exactly is wrong and why does it tap, and why does it still run? thanks ![]() Probably wise to say i wouldnt have that guy do the repairs if i were you.... ________________________________________ ''Oh, it does handle like a golf!'' Why drive a Golf....when you can drive a GTi-6? |
pugplus!
Seasoned Pro Location: Pontypool (southwales) Registered: 13 Feb 2009 Posts: 3,379 Status: Offline |
If your mechanic doesnt understand that then in all honesty I would be trying to find another one.It is 9 times out of 10 a bent valve or a damaged valve guide where a bent valve has been replaced in the past and the guides were not changed. It will still run fine usually as the valve will still seal but will make a noise whilst doing so. ________________________________________ Pugplus Peugeot parts specialists!!1000`s & 1000`s of new & used parts in stock International shipment Genuine Peugeot parts suppliers A range of Peugeot's for sale Contact info: Mob:07532066648 (richard) Email: pugplus@hotmail.com |
turna123
ok....wel is it worth me getting a new head? Been looking at a port and polished head...get that and put all new valves and valve seats in? |
sixqui89
Newbie Location: Staverton Registered: 15 Aug 2010 Posts: 26 Status: Offline |
Whatever you do, don't get some average brain dead grease monkey to try and sort it out for you...i did...and over 3 months and about £1500 later (including £800 recently) mine is still tapping You'd be better off going to a specialist who really knows what they're doing mate... |
turna123
tbh i can't be doing with the hassle anyway. Mine isn't running very well and sensors are all nakard. So i'm going for a new engine |
a new engine wont solve knackered sensors!________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
turna123
yes but it will come with newer throttle position sensor, newer coolant temperature sensor, newer lambda etc....agreed? :S |
