displaying posts 76 to 100 of 388
Pages (16): first .. 3 [4] 5 .. last
Author Subject: Midlife's Rallye
puglover Banned!
Post #76
LOL
Posted 5th Sep 2010 at 00:32
puglover Banned!
Post #77
midlife wrote:
It was only polished last time, the shells were all STD size.
Cool
you sure? it spun a bearing didnt it?
Posted 5th Sep 2010 at 00:35
midlife
Post #78
What are you on about GazDunno
You've NEVER actually finished anything!!!
Meh
Cool
Team 330™Cool
Team "no front end or engine"
Posted 5th Sep 2010 at 00:38
midlife
Post #79
puglover wrote:
Cool
I checked all the bearings & they were std size, perhaps the spun brg caused very little damageDunno
Cool
Team 330™Cool
Posted 5th Sep 2010 at 00:48
midlife
Post #80
Well it's update time again......
Decided to make a start on the head today
I've been looking in the cellar for my valve spring compressor with no joy, I ended up at Halfrauds having to fork out £50 for a new one Doh
It's a piece of p*ss to use once you have set the amount of compression correctly.
Each time I took a valve out I had a look to make sure there was nothing bent or damaged
& then like a good lad I bagged each assembly up together so nothing could get mixed up or lost
The valve stem oil seals came off easily with some snipe nosed pliers, must remember to get new ones as the removal fecks them up.
Once all the valves were out I had chance to attach my maniflow exhaust manifold & have a feel how good the match was between the exhaust ports & the manifold. The manifold ports were comfortably bigger than ports in the head so I knew I could safely do a little bit of porting.
I've ported heads before, the first one I did was a Mini Cooper S head probably before most of you were born. I was very inexperienced then & went at it like a bull in a china shop, I spent approx 30 hours on it & just as I was finishing off the last port I broke through into an oilway so head scrap.... That was very expensive to replace at the time as there was no such thing as Ebay to rely on.
Anyway now when I port a head I just look to remove casting imperfections & lumps & bumps that could disrupt gas flow, I tend not to care what it looks like as long as it feels good.
The exhaust ports had a few areas that needed a bit of attention, there is a casting line all the way around the middle of the port & there is a lump in the middle top & bottom that could go too as well as a few mismatches further inside the port.
Before
After
Side by side
Although the inlet ports were quite rough there was not much that needed doing apart from getting rid of a few minor lumps & a step on the corner of the valve seats.
Before
After
A little bit of tarting up in the combustion chamber
Before
After
Job done, only 3 more to do, I've now run out of emery drums for the Dremil & B&Q shut at 4pm so the other 3 will have to wait until next week.
On a lighter note when I went to Halfrauds to get the valve spring compressor there were about 4 of their spotty oiks stood round the till generally tossing it off so I asked them all if they stocked valve lapping paste, they all shrugged their shoulders and one said "what's it for, bodywork?"
FFS!!!!
Cool
Team 330™Cool
Posted 5th Sep 2010 at 22:48
Post #81
LOL
Down to a jewelers/repair shop and get some carbide polishing paste, most of 'em will stock it, or a diamond variant.
Silicon Carbide (the pink ones) grinding wheels work a lot faster on the dremel too....
Posted 6th Sep 2010 at 00:07
CUJ
Post #82
FFS!!!!
Cool
I do believe it's a pre-requisite on the Halfords application form that you have to be mentally deficient and have an HND in retardation.
Keep the updates coming, enjoying this thread Big grin
340 horses
Posted 6th Sep 2010 at 00:16
pete_rallye
Post #83
They do sell it, along with a grinding stick (aka bit of balsa wood with a sucker on the end). It even comes with 2 grades of grinding paste! For what it costs might be worth getting the head and valves on a Serdi machine and cut to match.
Lap of the 'ring
Posted 6th Sep 2010 at 00:26
midlife
Post #84
I ended up getting some from Abduls & a couple of sticks.
TBH the valves will need minimal lapping, there probably the best I've ever seen. I'll just give them a light going over.
Cool
Team 330™Cool
Posted 6th Sep 2010 at 00:31
mabgti
NV motors
Post #85
should always fully clean a degrease the ports before hand wayne... you can sumtimes just cut in extra shards of alloy which come off once the engine is ran in...
looks like you know what your doing anyway... so i'l just keep schtum..
Team Supercharged Gti-6
NV Motorsport
Automotive Performance Tuning
0121 448 7515
ECU Remapping/ DPF removal
www.nvmotorsport.com
Facebook Page
Project S6
Posted 6th Sep 2010 at 01:57
midlife
Post #86
Don't worry the ports were cleaned out with trike before I got stuck in & the full head will get several exceptionally thorough cleans when I'm done, thanks for your concernThumbs up
Cool
Team 330™Cool
Posted 6th Sep 2010 at 04:37
eddy_gti6
Post #87
head is looking good, wish i could be bothred. maybe take them bumps out of the exhaust outlets Big grin
Posted 6th Sep 2010 at 04:36
big g
Post #88
Meh
Cool
I have project back garden into workshop to concentrate on now.LOL
BRIGSPORT
Fridge men do it in the cold
TEAM Back garden into workshop
TEAM 306 meridian track car
TEAM I'm bored of thinking of stuff to put TEAM before.
Posted 7th Sep 2010 at 04:13
Post #89
He didn't even finish that bloody quote properly.
Posted 7th Sep 2010 at 04:19
mabgti
NV motors
Post #90
your avi makes me laff... gonna try it with a can of the finest!
NV Motorsport
0121 448 7515
Facebook Page
Project S6
Posted 7th Sep 2010 at 07:26
midlife
Post #91
Update time again.
Finished off porting the head today, here is a pic of the casting line that runs all the way around the middle of the exhaust ports
I couldn't bring myself to start lapping the valves in so I modified the Ancillaries bracket so that it would accept the supercharger mount. I know in Richw's instructions it says use a grinder but I'm an old school engineer & decided to do it the hard way!!!
I was quite shocked at how p*ss poor the casting was with loads of flash all over the show so I set about tidying it up, here is the finished article
Trial fitted onto my spare block
I'll take it for sandblasting this week
Cool
Team 330™Cool
Posted 13th Sep 2010 at 01:13
berger
Post #92
That engine crane looks too clean to me!
Bang'in 7 gram rocks!
I have one gear, GO!
Posted 13th Sep 2010 at 01:23
midlife
Post #93
Been doing a bit of shopping, I found a rosejointed gearlinkage that does away with the greasy ball jobbie on eBay being sold by Miles off here. I watched it fof a few days & stayed up till 12.45am to put a last second bid on it & got it for £---, bargain.
It arrived today & quietly away looks a tidy bit of kit!!
I got sick of doing 17 second quarter miles because the gear linkage had popped off going into second so fingers crossed this will stop it happening againNinja
Cool
Team 330™Cool
Posted 7th Jul 2014 at 23:00
Post #94
Must be why mine does 17 seconds ¼ miles, dodgy gearlinkage, I'd better check it Whistle
Posted 17th Sep 2010 at 02:59
eddy_gti6
Post #95
Cool
they look nice LOL i want sone, i had exactley the same problem with gear links popping off at york then the ball fell off the end of mine Angry
Posted 17th Sep 2010 at 03:08
Post #96
wonder where I can get a spherical joint like that one Hmm.
shouldn't be hard to make it fit, is it held in the tube bit by anything other than the linkages?
Posted 17th Sep 2010 at 03:16
midlife
Post #97
It's bolted to the angled bit & the bearing just slides in the bore. There is quite a bit of work gone on to make this thing, if you want me to post some better pics just shout up
Cool
Team 330™Cool
Posted 17th Sep 2010 at 03:51
Post #98
wouldn't mind if you could Smile
just considering a way to sort the worn rubber ball as you mentioned, the rest is in fair condition, and the brass Top hat bushes are very cheap from pug.
Posted 17th Sep 2010 at 03:58
birk
Post #99
I too also had the same problem at york LOL
I just got some solid gear linkages from miles, that fixed it Smile
Dimma + Gt35 turbo = Ninja
Solid rear beam mounts £130
07889376885
Dan
Posted 17th Sep 2010 at 06:03
midlife
Post #100
Extra pics as promised
Cool
Team 330™Cool
Posted 18th Sep 2010 at 00:36
