dented_vts has attached the following image:
| Author | Subject: Top mount nut- look right to you? |
dented_vts
Regular Location: london Registered: 23 Feb 2010 Posts: 440 Status: Offline |
Hi- just changed the front shocks and there seems to be more thread protruding than i remember, does that look right? They are OE dampers from the main stealer's that i have fit to replace the original items.dented_vts has attached the following image: |
dented_vts
slightly less thread is visible on the other side- what is wrong?dented_vts has attached the following image: |
cress87
Seasoned Pro Location: Norwich Registered: 30 Mar 2007 Posts: 11,360 Status: Offline |
Can't see on that top photo but is the washer under the nut present on both sides? Just double check everything was put back on the dampers and everything is seated properly.________________________________________ ![]() You feed beefburgers to swans. ![]() I may have been speeding Mr Policeman but [a] I live for the 306 and [b] did you see that dog? omfg |
steve954
Seasoned Pro Location: norwich Registered: 16 Nov 2008 Posts: 2,213 Status: Offline |
might just be the thread is a little longer, did you not get new nuts with the shocks?________________________________________ stevie09 308 gt140 cc 03 octavia vrs IF IT AIN'T BROKE, IT AIN'T A GTI6 |
bennn
Seasoned Pro Location: Shrewsbury Registered: 05 Sep 2008 Posts: 2,705 Status: Offline |
youve lost a washer by the looks of it!________________________________________ Cherry Red 306 HDIChampionship White Integra DC5 Type R |
dented_vts
There is a washer under both, but one is real rusty which makes me think its lived most of its life underneath the mount.I did buy new nuts and supplied them to the fitter...but they didnt use them! As far as i'm aware nylock nuts can not be reused and there is no thread lock on them either. |
dented_vts
Drat just measured it couple of mm less showing one side than the other! Not good- what is most likely to be missing washer under mount? |
dented_vts
dented_vts wrote: Drat just measured it couple of mm less showing one side than the other! Not good- what is most likely to be missing washer under mount? So its a number 71 i'm missing? dented_vts has attached the following image: |
mabgti
NV motors Location: Bham tunnel @7400rpm Registered: 28 Aug 2003 Posts: 9,127 Status: Offline |
look from underneath... got a feeling someones missed a washer on the rod before the cup![]() 71 ![]() ________________________________________ Team Supercharged Gti-6NV Motorsport Automotive Performance Tuning 0121 448 7515 ECU Remapping/ DPF removal VAG/BMW Diag and Option Coding Peugeot Planet ECU coding/transponder programming etc www.nvmotorsport.com Facebook Page Project S6 |
dented_vts
mabgti wrote: look from underneath... got a feeling someones missed a washer on the rod before the cup ![]() 71 ![]() Thanks for your reply mate- you think i will see it if i'm looking up at the strut from underneath? |
doubt it, it sits at the top of the bump stop and the dust cover/gator.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
dented_vts
welshpug! wrote: doubt it, it sits at the top of the bump stop and the dust cover/gator. Your right i had a look i cant see it! |
mabgti
you can pull the dust cover and bump stop down to reveal rod![]() ________________________________________ Team Supercharged Gti-6NV Motorsport Automotive Performance Tuning 0121 448 7515 ECU Remapping/ DPF removal VAG/BMW Diag and Option Coding Peugeot Planet ECU coding/transponder programming etc www.nvmotorsport.com Facebook Page Project S6 |
dented_vts
mabgti wrote: you can pull the dust cover and bump stop down to reveal rod ![]() I don't think you should be able to- the bump stop fits over the threaded part of the rod and supports the dust cover. The hole in the top of the bump stop is smaller than the diameter of the rod so it cant slide over it. |
mabgti
huh.. since when? the bump stop should be able to slide up and down the rod! stopping the rod from full compression using the shock sleeve and top mount!________________________________________ Team Supercharged Gti-6NV Motorsport Automotive Performance Tuning 0121 448 7515 ECU Remapping/ DPF removal VAG/BMW Diag and Option Coding Peugeot Planet ECU coding/transponder programming etc www.nvmotorsport.com Facebook Page Project S6 |
bump stop can slide all the way down, but they usually wedge themselves at the top.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
dented_vts
mabgti wrote: huh.. since when? the bump stop should be able to slide up and down the rod! stopping the rod from full compression using the shock sleeve and top mount! Thanks for your help mate. Maybe i have the wrong part then as i ordered part 4 in the pic from the dealers and the whole you can see i the top of the part is smaller than the smooth part of the shaft. On the knackered on it replaced, it was worn so that it would slide over the piston and hence when the suspension was fully extended the proctor fell down and exposed the rod. Maybe the Xsara stops are different? The dampers are different. |
dented_vts
What would happen eventually if the car is driven without the big washer- damage to the top mount? |
cress87
Would damage the bump stop if anything.________________________________________ ![]() You feed beefburgers to swans. ![]() I may have been speeding Mr Policeman but [a] I live for the 306 and [b] did you see that dog? omfg |
