Author Subject: Coil suitable for Omex and bodies?
devere
Just wanted to check if this coil is one that is suitable to run on an Omex ecu and throttle bodies?
ebay clicky
If someone could confirm one way or another would be most appreciated!
Cheers.
Posted 31st Aug 2010 at 02:38
depends which Omex, some need a wasted spark coilpack, in which case anything like that off the 8 valve xu or earlier TU enignes will do, as would a ford or GM coilpack, leads commonly used are ones like GM C16/18XE ones.
or you could trim a few lugs off the head and use the 16v xsi coilpack which doesnt need leads.
other ecu's higher up in the range will work the standard gti6 coilpacks just fine.
Posted 31st Aug 2010 at 02:42
devere
This is for the omex 600. So wont work with the standard gti6 coilpacks. If this one i linked to was suitable il just get this i think.. As long as it will work with the 600! lol
Posted 31st Aug 2010 at 02:47
miles
Yes that will work, I'd just get a XSi pack thou and with some triming you have a neat solution instead of HT leads kicking around
www.pugracing.com
Posted 31st Aug 2010 at 04:04
