Author Subject: Xantia Disc Clearance
berger
How much clearance do the Xantia 288mm discs have on the lower balljoint?
Does anyone have a photo of them fitted to the car from this kind of angle?
Clicky
Bang'in 7 gram rocks!
I have one gear, GO!
Posted 1st Sep 2010 at 02:26
more than that, but quite how much I can't remember!
you can work out how much there would be by looking at the disc brake catalogues and comparing the offsets and widths.
Posted 1st Sep 2010 at 02:30
berger
Need to know the thickness of the material which mounts onto the hub though which they dont give you.
You're only given the height and thickness of the disc, so you can have a couple of mm variance if the mounting face is thicker on one disc compared to another.
Posted 1st Sep 2010 at 02:32
good point Doh
some do specify that dimension iirc, but you do often get variations
Posted 1st Sep 2010 at 02:43
Rich E Forum Admin
The mounting material is 7mm on the 288x28mm Xantia discs.
There is a 0.8mm ± 0.1 offset between the mounting face and the outboard disc face, and the total disc thickness is also subject to a ± 0.1 tolerance.
So, if (and it's a big if!) I’m reading the drawing correctly the distance between the mounting face and the inboard disc face should be 27.2mm ± 0.2
Posted 2nd Sep 2010 at 05:23
