Author Subject: Fuel pressure regulator
mark-house
OK am i right in thinking that the pressure regulator on the XU10 engine runes at 3.5bar? and that this can be preplaced with a 4.5 bar regulator for a VAG car? If so does any one know what model VAG its from?
Peugeot 306 GTi 6
BMW 320 td compact M-sport
1967 Mini Cooper
1990 Jaguar XJR 4.0
Posted 7th Sep 2010 at 19:24
VR6
Posted 7th Sep 2010 at 19:34
james_gti6
i think they have 4 bar as standard on the a4 1.8t and golfs, was thinking of getting one aswell.
if i dont see you in the mattress il see you in the spring
Posted 7th Sep 2010 at 19:47
midlife
The sc boys use the vag 4 bar oneWink
Cool
Team 330™Cool
Team "no front end or engine"
Posted 7th Sep 2010 at 20:15
Why do you want one? I heard that the standard item is pretty capable Dunno
Posted 7th Sep 2010 at 21:11
mark-house
more air needs more fuel so ive been told Ninja
Peugeot 306 GTi 6
1967 Mini Cooper
1990 Jaguar XJR 4.0
Posted 7th Sep 2010 at 21:12
james_gti6
Supposed to give more pressure behind the injector giving a good mist when the injector is opened
Posted 7th Sep 2010 at 21:36
Yeah I know. Just depends how much more air your adding Happy
I was going to fit Jenvey throttle bodies to mine, and told the standard FPR would be fine.
Posted 7th Sep 2010 at 22:15
monkgti
theres this one but its only 4 bar
clicky
IF YOU CAN READ THIS IM STILL IN 5TH!!!
Posted 7th Sep 2010 at 22:22
eddy_gti6
do you realy need it at that price? LOL does it make any difference at all?
Clicky: [url =http://www.306gti6.com]click here[/url] remove the space between [url &amp; =
Posted 7th Sep 2010 at 22:32
maz-306-xs
I'm fitting my 'yanni style' r1 throttle body setup soon and I've been considering getting an adjustable one myself. Dont know if it's possible but I was hoping that with trial and error I should be about to find a good setup and avoid the remapping for now.
Does anyone know whether the adjustable ones ob eBay are worth a crack? At 35 quid I'm a little wary :-s
banned for drifting. back in the s**tbox scene.
Posted 7th Sep 2010 at 22:39
Buy a better quality one, if it runs lean it's bye bye engine.
Posted 7th Sep 2010 at 22:59
not really necessary when the pattern from the standard injectors is very good, and don't run anywhere near their limits at 3 bar.
raise the pressure and you'll shorten their lives and efficiency.
you wont get an engine to run well on t/b's without a remap.
Posted 7th Sep 2010 at 23:01
maz-306-xs
Think I'll leave it standard then, hopefully it should run fine anyway. Hopefully :-s
Posted 7th Sep 2010 at 23:13
anth
Your playing with fire mate.
Posted 8th Sep 2010 at 00:02
309btcc
**DODGY SELLER**
gti-6 runs 3bar reg not 3.5
Posted 8th Sep 2010 at 00:29
maz-306-xs
Don't say thaaaat! I've brought everything needed anyway so even if I fail I cant be put back to standard immidiatly, it should work, apart from giving the engine more air than normal it won't change it.
Posted 8th Sep 2010 at 00:50
309btcc
**DODGY SELLER**
leave it alone keep the 3bar reg its more than ample my friend trust me you dont want to be playing with it next thing you know bang its all over....
Posted 8th Sep 2010 at 20:57
