Author Subject: Remaps for Gti 6
123brez
wandering what is the best way to get more power out of
My Gti 6 that I bought last week. It's only got a scorpion cat back and a k and n 57i kit. Was thinking maybe a chip next?? Have been looking at a veizu remap which they reckon 20 - 30 bhp and 65 nm of torque. I thought this sounded a bit far fetched has any one had this done??? Cheers
Posted 10th Sep 2010 at 18:03
craigy_87
nah a remap isnt really needed without more work being done to the car
havnt experienced "chips" myself but always hear bad things but then dont quote me as like I said I havnt used one before
Posted 10th Sep 2010 at 18:12
lotek
you will get nowhere near that with a chip.
you will just end up with a over fueling car.
Posted 10th Sep 2010 at 18:13
aaron6
Sounds like too much to me. Think you would normally need a decat, cat back exhaust, decent induction and cams to see anywhere near 200bhp. Mine was rolling roaded at 176bhp with a longlife exhaust, decat and induction kit if thats of any help. I have put the cat on back on and it now feels like its got more torque. Smile
Posted 10th Sep 2010 at 18:14
123brez
Any ideas then plz lol. What's the best route to go down because Something needs to be done. Can't really afford a supercharger kit
Posted 10th Sep 2010 at 18:16
aaron6
Add cams and a decat followed by a remap for around a grand i expect. Should see reasonable power then i'd have thought.
Posted 10th Sep 2010 at 18:30
mabgti
NV motors
you gotta use an emulator to remap the 1ap properly... i only know of wayne schofield who has one.. alot of chip programming these days is via obd... hence why no one develops 1ap.. if i had enough interest id be willing to custom map them.
Team Supercharged Gti-6
NV Motorsport
Automotive Performance Tuning
0121 448 7515
ECU Remapping/ DPF removal
www.nvmotorsport.com
Facebook Page
Project S6
Posted 10th Sep 2010 at 21:15
123brez
Cheers will look into it
Posted 10th Sep 2010 at 21:31
braymond
wayne schofield remaped my standard ECU to run my cams. Im now producing 184 on his RR, but have no idea what the power was like before the cams, but its safe to say it probably wasnt 167..
Rallye-R
Nurburgring article
Posted 10th Sep 2010 at 21:55
mabgti
NV motors
peak figures are silly when talking nasp tuning.. running a bit more igntion advance and less fuel midrange is where the gti-6 makes it power.. It runs quite lean at 7Krpm s its quite hard to release the extra ponies without getting close to det.. especially with cams dialled in to incorporate longer duration of valves..
NV Motorsport
0121 448 7515
Facebook Page
Project S6
Posted 10th Sep 2010 at 21:59
123brez
If I get some cams will the car still run without a remap until I get set up??
Posted 14th Sep 2010 at 16:31
crasher1
i have got cams on my 6 and i havent had a remap and it still runs ok
My life is my 6
Posted 15th Sep 2010 at 22:05
mabgti
NV motors
It will ping.. causing knock detection... causing ignition retard... depends how well they are manually setup..
NV Motorsport
0121 448 7515
Facebook Page
Project S6
Posted 16th Sep 2010 at 07:58
mr swampy s16
**BAD SELLER**
mab can you remap tdci mondeo??
Posted 16th Sep 2010 at 15:48
what's an emulator?
probably have enough customers on here alone if you can offer the service without having to go oop north.
do you have a RR or would you do it on the road or use someone else's RR?
Posted 16th Sep 2010 at 16:09
bobdylan_55
wayne uses emulators as said, to live map the car, then when its right burns it to a chip and replaces the standard one.
309 GTi6-T
Posted 16th Sep 2010 at 16:10
mabgti
NV motors
an emulator simply emulates the original eprom, allowing for instant software changes between running.. before final burn and socket. nasp tuning on high compression engines requires just that... as combustion temps and pre ignition are very hard to avoid..
NV Motorsport
0121 448 7515
Facebook Page
Project S6
Posted 16th Sep 2010 at 16:26
mabgti
NV motors
i mainly map on the road, where real resistance and load is.. but use various rr's round uk.
RR will be going down end of 2010.
NV Motorsport
0121 448 7515
Facebook Page
Project S6
Posted 16th Sep 2010 at 16:28
mr swampy s16
**BAD SELLER**
can you do ford tdci??
what about pre multiplex 406 v6 ??
Posted 16th Sep 2010 at 16:30
