displaying posts 26 to 30 of 30
Pages (2): 1 [2]
Author Subject: Help: After Cleaning, Problems :(
Power steering sensor on the front of the car causes all sorts of funny things to happen to the running of the engine - seen it with my own eyes. Had a couple of cars come in with running probs - changed the sensor all sorted
Just my 2 pence worth if all usual suspects fail Smile
Posted 22nd Feb 2011 at 18:02
306gti6head
Where's the power steering sensor ? (any pics or is it obvious!)
& today it seems to idle just over 1k but NOT die !
Hmmmmm
Thank Phat Its Friday
Team: Ninja Gti6
Posted 22nd Feb 2011 at 18:05
306gti6head
Cleaned the Stepper motor & took the Map sensor off n kind of cleaned it a lil.
Car seems fine now, well at least for the moment Smile
Team: Ninja Gti6
Posted 22nd Feb 2011 at 19:36
gti-dan
bigbadbowen wrote:
Nope car will run fine without that pipe
Pretty sure that *could* be causing the problem. Yes - the car will run fine if nothing is connected to the cam over outlet, but at the other end of that pipe it is connected to the inlet behind the throttle plate so the engine can suck unmetered air through the pipe causing it to rev.
Could explain why the problem only kicks in after a while...could be that the pipe heats up a bit and the split allows air / more air down into the engine.
Unsure
Posted 23rd Feb 2011 at 00:02
Hmmmmm
Follow the power steering pipes bud its a blue sensor if I remember correctly ?
Posted 23rd Feb 2011 at 00:08
Pages (2): 1 [2]
