Author Subject: gti 6 head
tarret
hi ive got an s16, thinking of running it with a 6 head,
can anyone tell me will that work if so does it bolt straight on?
can i use my inlet/manifold?
ive got an zorst manifold so that would go on,
what other work/replacing parts are involved?
cheers
Posted 16th Sep 2010 at 00:50
yes it will bolt straight on, you'll need to use the gti6 timing gear on it with all the gti6 covers.
I wouldn't bother though, the Mi16/s16 head is very good already,the main restrictions are the exhaust manifold and mild cams.
Posted 16th Sep 2010 at 01:02
tarret
ok cheers, can i still use my inlet/manifold?
basically everything (breathers, sensors etc) same place?
I was going to run the 6 cams/pulleys and the zorst manifold,
what consists of the 6's timing gear?
Posted 16th Sep 2010 at 02:55
tarret
Posted 16th Sep 2010 at 23:52
the only gti6 bits that fit the S16 head is the inlet, nothing else will fit.
Posted 17th Sep 2010 at 00:12
tarret
yeah i was thinkin of using the 6 head, cams/pulleys and covers, exhaust manifold, and my s16 inlet,
all should be ok to run?
cheers Smile
Posted 17th Sep 2010 at 00:27
swiftyboi006
The gti 6 inlet would be better to use anyway?
Black p3 Love
Posted 17th Sep 2010 at 00:29
tarret
ok thank you Smile
Posted 17th Sep 2010 at 00:33
I'd love to see that done, you'd need to use the S16 ecu and injectors.
Posted 17th Sep 2010 at 01:25
tarret
so do what i was orignally going to do and run it with s16 inlet?
Posted 17th Sep 2010 at 03:10
