Author Subject: blowers not blowing cold
:: blade ::
reet, had this for a while, done a search a few weeks back and found out it could be one of 2 things, 1 being the heater switches and the other being the hot/cold air flap at the back of the dash, so i thought i would crack on and changed the switch to no availe. now onto the second option and thats to have a look at the hot/cold air flap, all i need to know is where abouts it is, and how i can go about fixing it without taking the dash out (if thats possible), as i pretty much die when out in the car with it blowing hot all the time, and have to have the windows open all the time.
hope someone could shed some light and help me out Big grin
cheers
Black Ph1 XSi-6
161.8BHP (Getting Better!!!!)
Posted 17th Sep 2010 at 00:06
its inside the heater box, on non a/c cars its on a cable so its probably broken or popped off the back of the knob.
Posted 17th Sep 2010 at 00:21
:: blade ::
should of really said in the 1st post, mines got a/c so its electronic, so i guess its a dash out jobbie, or can i get you it if i take the lower console out?
Black Ph1 XSi-6
Posted 17th Sep 2010 at 00:24
dan_s16
You can get to it just by removing the lower console but it's a pain in the ass, but as you have to remove the console to remove the dash you may as well start there and see how far you get.
Posted 17th Sep 2010 at 00:34
:: blade ::
i would be i dont really know what im looking for, what would go wrong on it, just need greasing/WD40ing up? or new motor time?
Black Ph1 XSi-6
Posted 17th Sep 2010 at 00:36
dan_s16
Sometimes they just pop out of the clips that hold them in, or it may need a new motor. it could also be a sensor but check to make sure the flap motor is secure first
Posted 17th Sep 2010 at 00:40
:: blade ::
will do cheers
Black Ph1 XSi-6
