Author Subject: gti 6 head/s16
tarret
ive got a 6 head which ill be putting on my s16, the head comes complete with cams, pulleys etc, also running the 6 manifold,
been told got to use the 6's timing gear,
what doesthis consist of?
does all the pipes/sensors etc basically fit in same places, cause ive noticed oil filler is in different place?
cheers
Posted 27th Sep 2010 at 02:50
mr swampy s16
**BAD SELLER**
No dont do it!
Fit the head but keep the s16 inlet!
Was always my plan
Posted 27th Sep 2010 at 02:58
tarret
i wasnt goin to fit the inlet only the head and exhaust manifold.
just need to know what the 6 timing gear is?
all the pipes etc basically go in the same place
Posted 27th Sep 2010 at 03:01
mr swampy s16
**BAD SELLER**
Cam belt. Tensioners etc
Posted 27th Sep 2010 at 03:03
tarret
so 6 cambelt kit?
also i noticed the filler cap different, so take the two oil breather pipes off my plastic filler and fit on to the 6 head?
Posted 27th Sep 2010 at 03:08
miles
Lower Belt drive wheel too, the 6 is half a tooth out compared to the Mi ones, which then means the 6 Drive pulley too
Pipes are quite different, I'd be temped to get a set of 6 water pipes really to make it P&P
www.pugracing.com
Posted 27th Sep 2010 at 03:13
tarret
drive pulley is this crank pulley?
and is the lower belt drive wheel the fan belt wheel?
cheers
Posted 27th Sep 2010 at 23:06
snillet
No, the cambelt drive pulley i would suspect.
This seems like a "big job" to me....
Isnīt the Mi16/S16 a quite good piece when it comes to flowrates?, the main advantage of the RS head is the oil drainage?
Member of Peugeot Sport Club Sweden
http://www.peugeot-sport-club.com/
My son: http://www.youtube.com/watch?v=jzjSBKkMHDA
Posted 28th Sep 2010 at 19:28
mr swampy s16
**BAD SELLER**
and the fact you can fit the nice flowing zorst manifold
Posted 28th Sep 2010 at 19:56
snillet
You mean the exhaust?
Posted 28th Sep 2010 at 20:09
mr swampy s16
**BAD SELLER**
the exhaust manifold is the main gain, from the cat back the exhaust is the same
Posted 28th Sep 2010 at 21:15
tarret
ok thanks guys Smile
i look forward to runnin it,
should be a fun job haha Big grin
Posted 28th Sep 2010 at 23:46
tarret
also ill be using uprated head gasket but would i use s16 headbolts or 6 headbolts?
Posted 30th Sep 2010 at 02:39
they're the same.
Posted 30th Sep 2010 at 02:46
tarret
ok cool, cheers Big grin
Posted 30th Sep 2010 at 02:54
miles
Just use the std 6 H/G, it's MLS as std
www.pugracing.com
Posted 30th Sep 2010 at 05:00
tarret
h/g- headgasket?
ok thank you, saves me some money lol
Posted 1st Oct 2010 at 00:34
tarret
can anyone tell me the 6 head has two oil pipes connectin to the right side where as the s16 has one, does the other oil pipe come off the s16 oil filler cap cause dont need it when the 6 head is on
Posted 2nd Oct 2010 at 03:15
