Author Subject: Fuel pump relay question
fugs
I have changed the ecu in my car after haveing many problems getting it started. Its no longer immobilised and has spark etc but the fuel pump will not run. I know its to do with slightly different wiring. I need to connect into pin14 on the relay but from what pin?
Can anyone help please?
Posted 2nd Oct 2010 at 19:01
fugs
I should probably explain this a bit better.
I changed to an unlocked and remapped ecu which was once used in a 205 gti-6 track car. I fitted to my car as I had ecu and immo problems. I now have spark and injectors are working etc.. so the ecu is working and I removed my immobiliser. Now the fuel pump is not working but it was before hand (Only on the initial prime). The guy who sold me the ecu said to connect the positive for the fuel pump to pin 14 on the on the fuel pump relay. I don't know as yet if this will work. Which wire at the pump is this? I'm gueassing the blue wire and where in the loom is this wire? I cannot seem to find it.
If I can't get this wire I'll have to wire the pump direct from the battery with a switch inside. Which actually for a track car would be kinda cool.
Posted 2nd Oct 2010 at 23:17
you wouldn't have to alter any of the wiring, the ecu's are all the same.
they also don't prime every time.
Posted 2nd Oct 2010 at 23:31
fugs
The fuel pump worked with the old ecu. Its not working at all with this ecu in.
Posted 3rd Oct 2010 at 17:23
fugs
Can anyone tell me which wire on the pump is positive? I'm guessing the 2 small ones are for the fuel guage.
Also does the ecu hold the mileage data etc... the little digital display is now blank.
Posted 4th Oct 2010 at 02:53
mabgti
NV motors
ecu doesnt hold the mileage dataNo
sounds like you have blown a fuse.. fuel pump and dials maybe...
Team Supercharged Gti-6
NV Motorsport
Automotive Performance Tuning
0121 448 7515
ECU Remapping/ DPF removal
www.nvmotorsport.com
Facebook Page
Project S6
Posted 4th Oct 2010 at 07:07
fugs
I've checked all fuses and they are ok. No mileage up and still no kick from fuel pump! Looks like the fuel gauge is not working too.
Posted 4th Oct 2010 at 21:46
fugs
Wired pump off the battery and it runs
Posted 4th Oct 2010 at 23:27
fugs
Problem sorted. Some very didgy wiring was done on this car at some stage!
Posted 5th Oct 2010 at 20:23
