Author Subject: gti6 mi16
pugben
Hi is the inlet the same on a gti6 as mi16? do the manifolds swap over, studs in same place? cheers
BHARVEY
Posted 3rd Oct 2010 at 21:41
no not the same.
yes it will fit, lots of messing about with the pipework though.
Posted 3rd Oct 2010 at 21:45
mr swampy s16
**BAD SELLER**
Keep the s16 avac inlet.
When its correctly set up and working correctly it very good
Posted 3rd Oct 2010 at 22:11
pugben
after putting carbs on a gti6 lump have seen a manifold for an mi16 just wanted to know if it would fit
BHARVEY
Posted 3rd Oct 2010 at 22:42
dont put carbs on it, they're crap Razz
T-B's and management or nowt!
Posted 3rd Oct 2010 at 22:46
pugben
engines not in a 306 its in a 205 have run carbs for years with no probs and with an impressive power figure and soundtrack
BHARVEY
Posted 3rd Oct 2010 at 23:08
rallyeash
ignition ecu FTW then.. Smile
309 3dr K20 Type R
Posted 3rd Oct 2010 at 23:10
pugben
just wanted to know if inlet was same as mi16?
BHARVEY
Posted 3rd Oct 2010 at 23:32
rallyeash
no
309 3dr K20 Type R
Posted 3rd Oct 2010 at 23:53
miles
Yes the Jenvey inlet is the same on any Pug 16v XU engine
Fitting carb's thou I doubt will gain any power or torque as the std inlet is very good, but will sound better
www.pugracing.com
Posted 4th Oct 2010 at 00:19
monty-69
You will see similar power/torque increases to fitting throttle bodies if set up correctly.
Posted 4th Oct 2010 at 00:23
pugben
my 205 is running carbs at present on 8v so will just swap it all over to 16v lump with new inlet manifold saves messing with all the wiring
BHARVEY
Posted 4th Oct 2010 at 01:04
I'd rather mess with the wiring (4 or 5 wires to make it run btw...) than run carbs.
last gti6 engine I heard of running carbs made 170 bhp.... Laugh my ass off
Posted 4th Oct 2010 at 01:11
pugben
more than current 8v !
BHARVEY
Posted 4th Oct 2010 at 01:19
miles
But the std 6 engine makes only a couple less and hence my comment really,
The wiring or if someone did a plug and play loom would be cheaper than setting the carb;s up again, Unless you can DIY them
And to further on the inlet's, only buy the Jenvey one, others can be had £20 or £30 cheaper but you'll spend allot of time making them fit
www.pugracing.com
Posted 4th Oct 2010 at 03:59
