Author Subject: brake pipe union screws
a morgan
i have changed my master cylinder but fluid is leaking from the union screw middle bit where the pipe goes. where can i buy new union screws or do i have to buy the whole lot connection and pipes. but from where?
thanks
a morgan
Posted 9th Oct 2010 at 19:28
mr swampy s16
**BAD SELLER**
Will be a new pipe, complet with unions.
Some where like parkers can make them up for you
Posted 9th Oct 2010 at 20:01
a morgan
made to measure ok will do. thank you
a morgan
Posted 9th Oct 2010 at 20:15
oldbrownshoe
If it's the long pipe that running all the way to the caliper , you better give up.
it's just impossible to install it with the engine in place.
but there's a way to overcome that without removing the engine.
French military victories?
Did you mean French military defeats?
Posted 20th Oct 2010 at 04:43
smegal
Buy measure a route through a hole up to the next connector with a piece of string then get a section of copper brake pipe made up and fit it.
Ex SC-6
Now in a Megane R26
Posted 20th Oct 2010 at 04:46
oldbrownshoe
I just ordered to cut in a workshop the new pipe to 3 parts and connect them with proper fittings
Posted 20th Oct 2010 at 07:08
oldbrownshoe
It's should be obvious , but worth mention ,
the flair in each ends have to be in 37 angle.
Posted 20th Oct 2010 at 16:00
