Author Subject: 306 gti 6 hub
mattgti6phase2
does anyone know if a hub on a gti 6 would be the same as the hub on any other ordinary 306???? i need a new hub as mine is bent but dont really know where to get one from
Team Nile 6 Superman
Team: 40.2 MPG Smile
5 x a 306 owner!
I truely live for the 306 ®
midweek madness Tee hee
Posted 9th Oct 2010 at 23:43
jim01uk
need to check it has the right size balljoint clamp hole (18mm IIRC) and that there is a hole for the ABS sensor.
Posted 9th Oct 2010 at 23:51
mattgti6phase2
thanks for the advice. i assume if they are the same as my current then the new one will fit?
5 x a 306 owner!
Posted 9th Oct 2010 at 23:54
jim01uk
Yeh can't see why not!
Posted 10th Oct 2010 at 00:00
chrisd306
get in touch with rolandrat or hanpug25 or pugplus as they may have one lying about, doesnt matter on hub you get just replce the ball joint aswell to suit the hub, there only like 5.50 or something from motor factors, ive got to hubs but 1 has a f*cked wheel bearing!
In my garage just now
& Audi Q5 S Line
AX stock rod & Saxo Stock rod
Posted 10th Oct 2010 at 00:36
ablister
aren't wheel bearings a different size on the base model 306's? Something like 82mm diamater for sports suspension (gti6/xsi etc) and 72mm for others
306 rallye, Richard Longman engine
rc10gt
Posted 10th Oct 2010 at 02:03
bar the non abs 1.4 TU's, I believe all the rest are 82mm.
Posted 10th Oct 2010 at 02:16
mattgti6phase2
thanks guys. so a hub from a 306 with abs shud be the same fitment?
5 x a 306 owner!
Posted 10th Oct 2010 at 03:04
chrisd306
hopefully, try the few guys who break on here.
becareful when removing your abs sensor from your hub to fit in replacment hub as normally break, an when fitting the new 1, give the hub a good clean with emery paper an put copper slip on the sensor so it ease'is in.
& Audi Q5 S Line
Posted 10th Oct 2010 at 03:32
