Author Subject: cam timing
james_gti6
in the middle of fitting the newman ph2 cams today and found who ever did the cambelt before has not timed it correctly, the 10mm bolts are right to the end of the elongated holes in the pulleys, the car seem to pull very well and havnt seen any problems, i will obviously rectify this when i put the new belt on, anybody else had this and was there any difference in power once times correctly.
if i dont see you in the mattress il see you in the spring
Posted 10th Oct 2010 at 04:44
was it just the inlet and was it further forwards?
that's called advanced Smile
Posted 10th Oct 2010 at 05:11
james_gti6
the both pulleys which is the strange thing. i cant remember which way around they are now, i will check in the morning and get a pick up. o do know those 10mm bolts should be central.
Posted 10th Oct 2010 at 05:19
naah, doesn't matter where they are as their position even when pinned up 100% bang on is affected by belt tension.
if both are out it may be that the bottom pulley has slipped.
Posted 10th Oct 2010 at 14:31
