Author Subject: door wireing question
loftlex
Hi
as most of you know i have a diesel, but this forum is the best for getting advice on 306's
so,, my drivers door sometimes locks, sometiems it does not, also my windows, sometimes work and somtimes they do not..
but opening and closing my door fixes the problem..
so i am 99% sure its the wireing loom connecting the door to the cars body..
on closer inspection my wireing loom has been butchered and is held together with cable ties and insulation tape,,,
i went to the scrap yard today and found a donour 306 with the wireing loom in good condition,, (but its from the passengers side, not the drivers side, do you think it will work) also it does not apear to be able to be disconnected via a plug or connection block and there is not a lot of room to move,, do i have to snip the wires and re solder them? to a better condition door plug?
and seeing most of you on here have converted your 306's to rallye's have any of you got a standard door electrical loom that is slightly longer so i can have more room to solder the connections in place,,
i need the loom that runs inside the car, that runs to the door and has a twist off connector that plugs in to the door...
any help advice or pointers would be great
GTI wanna be Sad ---In a puff of black smoke and a whistle,,, i was gone Smile
Posted 17th Oct 2010 at 22:42
andy306gti
If I recall right peugeot sell a repair loom for the door. You'll probably need to remove the door from its hinges to get engought access to repair it...
I remember reading a thread on here with someone doing just that.
Posted 18th Oct 2010 at 05:09
andy306gti
This is probably the page you want... Third post down.
I wouldn't think it'd be worth using a scrap loom as chances are it'll happend again rather soon. Either get a repair loom from peugeot or repair the one you have by cutting it down past the damaged cable and extending the wiring.
Posted 18th Oct 2010 at 05:23
loftlex
ooo, thanks Smile
Posted 18th Oct 2010 at 14:24
lotek
dont get a used one! even from another gti6 as the colour wires vary from each car , there little c*nts ! Yes
buy a repair loom , or even easier just repair your own. Yes
]dont do what i did and snip it off and try to fix with donor connector. it doesent work,
thankfully i have Central locking working again , and have hard wired my windows via 3way switch
Posted 18th Oct 2010 at 16:33
loftlex
ok, i'll have a go at repairing my own loom then,, many thanks Smile
Posted 18th Oct 2010 at 20:02
mwl001
This is how I fixed mine:
clicky
Posted 19th Oct 2010 at 01:34
mine's always gone in my ownership of every 306 i've had. easy fix if you can solder and heatshrink etc, did mine on the 6 in january and all is well still
Posted 19th Oct 2010 at 03:38
loftlex
well i had no choice but to try and fix it today Sad
put my window down, and it started to rain,,, and it would not go back up
bo***cks Sad
so,, when the rain stopped for a while i had to strip the door connector and re do it all
mine has been propper butchered so i am going to have to replace it,, four of the cables are less than a cm long Sad
i soldered cable and heat shrink cabled round the soldered joints,, so its a reasonable job
it works for now but it wont last long,,
so i am gonna have to find a sutible replacement
bugger Sad
Posted 20th Oct 2010 at 01:26
