Author Subject: 6 Cam Pulleys for xsi
benn25
Looking to change cam pulleys in my xsi to 6 version. Will these fit straight in? When I get the 6 cams will it fit straight in or will i have to tinker. Plus is there anything else I will have to replace with 6 items. Cheers.
Posted 18th Oct 2010 at 01:36
exhaust pulley hub is the same as the gti6,and the gti6 uses identical ones inlet and exhaust.
the outer pulley is the same on all of them.
gti6 cams would go straight in, but you have an oil feed on the end of the exhaust cam that needs to be plugged.
Posted 18th Oct 2010 at 02:58
benn25
Many thanks welshpug. Your a gentleman and a scholar.
Posted 18th Oct 2010 at 15:42
benn25
Is the oil feed you talking about the vacuum pump for the brake servo???
Posted 26th Oct 2010 at 00:22
