Author Subject: cambelt tensioner confusion
jimmyboycheck
the rest of the kit looks fine, is the tensioner on the left for a vts or something?
Silver 6
Posted 18th Oct 2010 at 15:53
jeffers Forum Admin
I think that its a 137 tooth kit whereas the tensioner on the right is off a 136 tooth kit.... i'm sure someone will come along and correct me if i'm wrong! LOL
Team Running Engine again!
Team Negative Camber!
Posted 18th Oct 2010 at 16:05
jimmyboycheck
the one on the left will not fit. the kit was apparently for gti6/vts so is the tensioner for vts. the guide was the same tho
Silver 6
Posted 18th Oct 2010 at 16:16
jimmyboycheck
speaking to europarts this morning, the chap said there is two diffrent cambelt kits. 1 being self adjuster ie on the left in pic or manuall adjust. So hopefully the rest of the kit is ok...........
Silver 6
Posted 18th Oct 2010 at 16:20
it wont be, the belts are a different length by one tooth.
Posted 18th Oct 2010 at 22:03
Rich E Forum Admin
As above, you need to take the kit back and get the 136 tooth kit.
Posted 19th Oct 2010 at 18:50
jimmyboycheck
well the belt was 136. the tensioner was wrong. i measured up the belt and was 136. now on the car and runing perfect. it looks like tensioner and belt were packed seperatly
Silver 6
Posted 19th Oct 2010 at 18:52
rallyeash
awaiting the bent valve thread...
309 3dr K20 Type R
Posted 19th Oct 2010 at 21:34
jimmyboycheck
so could someone tell me what car the tensioner is on the left for. So I can sell it on...thanks
Silver 6
Posted 19th Oct 2010 at 21:57
its from the 137t kit by the looks of it.
Posted 19th Oct 2010 at 22:38
xsisid
the one on the left is for the 1.8 xsi engine. its the only engine that uses that tensioner. i found some info on it on the gates site a while ago.
Posted 20th Oct 2010 at 02:45
jimmyboycheck
seriously if this was the case how long would it take for this to happen. i did measure it up to the belt that came off up and matched tooth to tooth all the way round. or are you taking the p*ss cos you can use 137 or 136 tooth belt..............
Silver 6
Posted 20th Oct 2010 at 04:22
miles
Those tensioners are not bad really, the V6 uses them and never get changed until the 2nd belt around 145,000 miles, Saves sticking too much tension on the belt, But more hassle to fit on the 6 engine
www.pugracing.com
Posted 20th Oct 2010 at 04:27
rallyeash
only joking mate.
309 3dr K20 Type R
Posted 22nd Oct 2010 at 14:51
