displaying posts 26 to 50 of 51
Pages (3): 1 [2] 3
Author Subject: Engine Idling at 2k rpm **HELP PLEASE**
Checked the blue temp sensor on the thermostat housing ?
Failing that I would have the inlet manifold off and replace the gasket they are after all only a paper thing Wink
Posted 26th Nov 2010 at 00:36
:: blade ::
all been checked, will be changing the inlet gasket next week as ive got a pfte one to fit, so fingers crossed all will be well by the end of next week
Black Ph1 XSi-6
161.8BHP (Getting Better!!!!)
Posted 26th Nov 2010 at 00:39
well if you have changed everything else then must be gasket Wink at an outside shot it could be the power steering sensor at the front of the engine - it has been found to cause all sorts of strange goings on when faulty Wink
Posted 26th Nov 2010 at 01:59
brownboy
i can recommend these and they aren't far from you mate
http://jc-webs.co.uk/mikeanics/
Posted 26th Nov 2010 at 02:03
:: blade ::
cheers
there abit too far for me as im in preston at the weekends, but will look into it,
Black Ph1 XSi-6
Posted 26th Nov 2010 at 02:17
:: blade ::
will go check the power steering sensor Smilecheers
Black Ph1 XSi-6
Posted 26th Nov 2010 at 02:20
brownboy
these are good to
http://www.ladmotorsport.co.uk/
Posted 26th Nov 2010 at 02:22
LOL
Posted 26th Nov 2010 at 02:30
brownboy
LOL
im talking from first hand experience here !!! Whistle
Posted 26th Nov 2010 at 02:31
:: blade ::
Post #35
aww dont laugh Sad you could at least help :p
Black Ph1 XSi-6
Posted 26th Nov 2010 at 02:32
:: blade ::
Post #36
just been out to look for the connector to put it on a diagnostics machine, did a search on here to find the places where they are, and cant find it in the places, so maybe it was taken out with the old engine when i did the conversion? so looks like im going to have to fault find and start fitting new bits everywhere till is stops, first thing to do is to put the PTFE gasket on
Black Ph1 XSi-6
Posted 26th Nov 2010 at 03:19
mattgti6phase2
Post #37
Ptfe gaskets any good? What's the difference?
Team Nile 6 Superman
Team: 40.2 MPG Smile
5 x a 306 owner!
I truely live for the 306 ®
midweek madness Tee hee
Posted 26th Nov 2010 at 12:58
Post #38
stops heat soak from head to manifold, made 1 bhp gain at a rolling road in Andover many years ago Wink
Posted 26th Nov 2010 at 22:26
Post #39
brownboy wrote:
these are good to
ha ha ha ha have you seen the complete dog turds this lot turn out ?
I wouldn't let them fix a puncture on my push bike,
Posted 26th Nov 2010 at 22:27
brownboy
Post #40
bigbadbowen wrote:
brownboy wrote:
these are good to
ive had my head gasket done by them and the cambelt and have nothing but praise thanks also they did good work on the head of daveyboys car when it was my next door neighbours car like i said i have first hand experience of there work a wouldnt hesitate to recommend them
Posted 26th Nov 2010 at 22:40
:: blade ::
Post #41
Just been thinking, once i have changed the other bits and i still get this prob, would it be worth changing the tps? Or would that have different symptoms?
Black Ph1 XSi-6
Posted 28th Nov 2010 at 19:06
Post #42
check the testing sensors FAQ, it'll save you a lot of cash
Posted 28th Nov 2010 at 20:07
:: blade ::
Post #43
Shall do Smile got me a multi meter yesturday, so will test when im putting the ptfe gasket on
Black Ph1 XSi-6
Posted 28th Nov 2010 at 21:30
gti-dan
Post #44
Any joy with this problem yet?
Posted 15th Jan 2011 at 23:12
:: blade ::
Post #45
Yea, tured out to be a nakered inlet gasket, was all fine once i fitted the ptfe gasket
Black Ph1 XSi-6
Posted 15th Jan 2011 at 23:51
speedo306
Post #46
Does a faulty icv cause the car to "buck" on you when driving? i have been getting a similar problem with my idle changed the gas pump, the crank sensor, the fuel filter and the multi-function relay and cleaned the stepper motor and the idle problem and "buckering" persists.
RJ
Posted 16th Jan 2011 at 01:38
greenbelt
Post #47
MAP sensor Wink
Standard Black 6
Black HBSC6 Smoke
Posted 16th Jan 2011 at 01:39
speedo306
Post #48
greenbelt wrote:
MAP sensor Wink
Going to change it now. Can this also cause the car to shut down?
RJ
Posted 16th Jan 2011 at 01:52
greenbelt
Post #49
If you disconnect it when the engine is running it will cut out.
Standard Black 6
Black HBSC6 Smoke
Posted 16th Jan 2011 at 01:57
speedo306
Post #50
Are you suggesting the map sensor should be replaced? Also is this the only thing that will cause my problem.
RJ
Posted 16th Jan 2011 at 02:08
Pages (3): 1 [2] 3
