Author Subject: Fuel pump relay location
shimmy
Does anyone know?
Thanks
Team V6
Posted 11th Nov 2010 at 13:54
CUJ
Pretty sure it's usually found attached to the back of the battery box?
340 horses
Posted 11th Nov 2010 at 15:29
jeffers Forum Admin
Bolted to back of ECU/ battery box! Thumbs up
Team Running Engine again!
Team Negative Camber!
Posted 11th Nov 2010 at 18:32
shimmy
Thanks chaps, bit of a short first post, using a mates phone that is impossible to work.
Thanks again
Team V6
Posted 12th Nov 2010 at 04:10
You've got two relays the same in your car now One runs the fuel, the other the coilpack iirc. If you aren't getting power to the fuel pump its either:
1. immobiliser issue, but shouldn't be as you've got an unlocked ecu
2. you've blown the ecu up
3. dodgy wiring
Posted 14th Nov 2010 at 22:59
shimmy
I think the fuel pump is working.
Was idling for a few minutes then conked out and now won't start again.
What else could it be?
Team V6
Posted 15th Nov 2010 at 01:06
Coilpack. Crank sensor....?
Posted 15th Nov 2010 at 01:32
run out of fuel? LOL
Posted 15th Nov 2010 at 01:35
shimmy
Well, the light was on so it went to the petrol station and had £15 of the finest LOL . Then 10 minutes later nothing.
Okay il investigate anything else. Didnt you have new coilpack on yours?
Team V6
Posted 15th Nov 2010 at 02:00
shimmy
Think its been narrowed down to the crank sensor, any idea of price of a new one?
Team V6
Posted 15th Nov 2010 at 03:42
£15 odd from GSF.
Posted 15th Nov 2010 at 14:58
shimmy
Just bought one from my local auto parts place, be there 1.30ish £19 so not bad. Whats the canister thing attached behind the tb?
Team V6
Posted 15th Nov 2010 at 17:49
idle valve LOL
Posted 15th Nov 2010 at 17:54
shimmy
Changed the crank sensor and still wont go, any other ideas?
Team V6
Posted 18th Nov 2010 at 17:20
What ECU are you using?
Posted 18th Nov 2010 at 19:14
shimmy
Yours, i have an unlocked one aswel, tried that and still nothing?
Team V6
Posted 18th Nov 2010 at 19:39
