| Author | Subject: Harris' SC China Track Car attempt |
Post #676
Yes you are.________________________________________ Membership expiring soon, get in contact on our new little forum project. |
Seasoned Pro Location: Parts for Sale section Registered: 04 Dec 2007 Posts: 7,442 Status: Offline |
Post #677
Pretty much sure the little bracket on the left hand side of this is for the brake compensator valve.![]() I dont need this so attacked it with the angle grinder. ![]() ________________________________________ Chris1999 China Gti6 Supercharged [Fun car] >>Project Thread<<2000 Bianca 306 Diesel [Work runabout] |
Post #678
I will have to try that Deox-C.I've been doing much the same preparing a 309 beam. Although I put it on hold after cleaning up a disc protector with a wire knot wheel on my angle grinder held between my patented feet-vice. I must have caught an edge badly as it flung the protector to the back of the shed and the grinder into my leg. Luckily it was the body of the grinder that hit me. This gel sounds like a safe choice. ________________________________________ ![]() |
scotzman
Seasoned Pro Location: Dundee Registered: 24 Jun 2011 Posts: 1,408 Status: Offline |
Post #679
quote: dangti6 wrote: .This gel sounds like a safe choice. There are 2 types Deox-C and Deox Gel, the Deox-C comes as a powder and you mix it with water, this works the better of the 2 but if its something too large to soak in the solution you will have to use the gel. ________________________________________ '90 1.6 205 GTi, '98 306 GTi-6 |
Post #680
Lucky escape Dan ![]() And yeah I bought some Deox-C powder and Deox-C gel. Anything that is small enough to be submerged in water use the powder solution, if its not, used the gel. The gel will also be handy cleaning up under the car/boot floor area ![]() ________________________________________ Chris1999 China Gti6 Supercharged [Fun car] >>Project Thread<<2000 Bianca 306 Diesel [Work runabout] |
Post #681
Scotzman beat me to it ![]() ________________________________________ Chris1999 China Gti6 Supercharged [Fun car] >>Project Thread<<2000 Bianca 306 Diesel [Work runabout] |
scotzman
Post #682
cjm_harris wrote: Scotzman beat me to it ![]() Stuff is awesome though, I recently did a set of calipers, they came up really well. ________________________________________ '90 1.6 205 GTi, '98 306 GTi-6 |
Post #683
Yup, this is how my ARB fixings came up with a soak in some deox-C:![]() Magic stuff. ________________________________________ Membership expiring soon, get in contact on our new little forum project. |
Post #684
Yup, not only is it good at its job, the best thing is it requires f**k all work from us ![]() ________________________________________ Chris1999 China Gti6 Supercharged [Fun car] >>Project Thread<<2000 Bianca 306 Diesel [Work runabout] |
Post #685
It's exactly my kind of stuff, throw it in and come back to it a day later and it's done all the hard work for you. Get in.________________________________________ Membership expiring soon, get in contact on our new little forum project. |
Post #686
Is it available on the high street at all? ________________________________________ ![]() |
Post #687
dangti6 wrote: Is it available on the high street at all? Not that I know of mate, I wouldnt know where to look round my way, sure Halfords etc wont have it ![]() I bought mine from Opie oils and made use of an offer they had on. ________________________________________ Chris1999 China Gti6 Supercharged [Fun car] >>Project Thread<<2000 Bianca 306 Diesel [Work runabout] |
Post #688
I think I'll go for the powder. Got a small cat trespass issue so this may eradicate more than rust if I leave something outside soaking in a bowl.________________________________________ ![]() |
Post #689
dangti6 wrote: Is it available on the high street at all? buy it direct http://www.bilthamber.com/ ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
Post #690
Contact Bilt Hamber Laboratories directly:http://www.bilthamber.com/ 01277 658899 ________________________________________ R H Davey Welding Supplies. I sell new and used welding equipment in the Hampshire area. I take on welding jobs in the evenings, ally casting repairs are one of my specialities but I can weld pretty much anything. PM me with your requirements.Some of my services: (See my for sale threads) Engine mount/chassis repair Solid Beam Mounts BACK IN PRODUCTION Harness bars |
Post #691
Edit: beaten to it by the Welshman.________________________________________ R H Davey Welding Supplies. I sell new and used welding equipment in the Hampshire area. I take on welding jobs in the evenings, ally casting repairs are one of my specialities but I can weld pretty much anything. PM me with your requirements.Some of my services: (See my for sale threads) Engine mount/chassis repair Solid Beam Mounts BACK IN PRODUCTION Harness bars |
Post #692
It also makes quite a big difference if you use warm water, just make sure you get rid of any loose rust then leave it to soak. I ordered all mine from Bilt Hamber direct, along with a load of their Etchweld primer which is also pretty good. ________________________________________ Membership expiring soon, get in contact on our new little forum project. |
Post #693
cjm_harris wrote: ![]() I'd have ground off the rest of the bracket, and probably drilled some holes too... I need to get out more. ________________________________________ R H Davey Welding Supplies. I sell new and used welding equipment in the Hampshire area. I take on welding jobs in the evenings, ally casting repairs are one of my specialities but I can weld pretty much anything. PM me with your requirements.Some of my services: (See my for sale threads) Engine mount/chassis repair Solid Beam Mounts BACK IN PRODUCTION Harness bars |
Post #694
owain wrote: It also makes quite a big difference if you use warm water, just make sure you get rid of any loose rust then leave it to soak. I ordered all mine from Bilt Hamber direct, along with a load of their Etchweld primer which is also pretty good. Yeah I used warm water too, but from the looks of the guide sheet that came with it, just helps with dissolving the powder in the first place? ________________________________________ Chris1999 China Gti6 Supercharged [Fun car] >>Project Thread<<2000 Bianca 306 Diesel [Work runabout] |
Post #695
daveyboy wrote: I'd have ground off the rest of the bracket, and probably drilled some holes too... I need to get out more. Pfft, its going under the car, its lucky I even cut that off ![]() ________________________________________ Chris1999 China Gti6 Supercharged [Fun car] >>Project Thread<<2000 Bianca 306 Diesel [Work runabout] |
Post #696
Warm water will become cold in an hour, it's just nicer to work with initially, especially this time of year.________________________________________ R H Davey Welding Supplies. I sell new and used welding equipment in the Hampshire area. I take on welding jobs in the evenings, ally casting repairs are one of my specialities but I can weld pretty much anything. PM me with your requirements.Some of my services: (See my for sale threads) Engine mount/chassis repair Solid Beam Mounts BACK IN PRODUCTION Harness bars |
Post #697
I did mine all inside the house and left them near a radiator, doesn't make a world of difference but every little helps. ________________________________________ Membership expiring soon, get in contact on our new little forum project. |
Post #698
Question guys..The bolts that go through the brackets shown above were pretty corroded, and the nuts seemed fubar'd. I went to buy a couple of new ones today and the place I tried to buy them from couldnt get them to fit properly and said it was probably due to the thread being slightly damaged. Bought some new bolts and nuts from them, but they have a shorter shank on them, will this be a problem? They were cheap enough so worth the punt, but want to check if they will be ok. Corroded thread on original bolt ![]() Old vs new ![]() ![]() Also, does anyone know what tensile strength the original ones should be? The new ones are 8.8 Cheers ________________________________________ Chris1999 China Gti6 Supercharged [Fun car] >>Project Thread<<2000 Bianca 306 Diesel [Work runabout] |
Post #699
The new nuts wouldn't fit because the thread pitch is different.________________________________________ R H Davey Welding Supplies. I sell new and used welding equipment in the Hampshire area. I take on welding jobs in the evenings, ally casting repairs are one of my specialities but I can weld pretty much anything. PM me with your requirements.Some of my services: (See my for sale threads) Engine mount/chassis repair Solid Beam Mounts BACK IN PRODUCTION Harness bars |
Post #700
daveyboy wrote: The new nuts wouldn't fit because the thread pitch is different. ![]() Yeah I know that. Should of mentioned, I didnt buy the other nuts, but they measured the thread pitch of the bolt I gave them and tried a nut with the same pitch. It didnt fit, so they sold me the pictured nuts and bolts instead. ________________________________________ Chris1999 China Gti6 Supercharged [Fun car] >>Project Thread<<2000 Bianca 306 Diesel [Work runabout] |
